[Ovmsdev] CAN-3 broken again?
Thu Jan 11 20:42:24 HKT 2018
Greg, Mark,
I can check your new code after work.
For the TX performance/overflow issue, there are basically two options:
* A: make all application TX be aware of overflows, i.e. check the return value of the CAN Write() call as necessary and/or introduce
sufficient delays (very ugly)
* B: add a TX queue to the CAN framework, so the application can just push some frames as fast as it likes, with an option to wait/block/fail
if the queue is full
o → the framework checks for TX buffers becoming available (i.e. driver issuing a TxCallback request) and delivers queued frames only as
fast as the driver can handle them
Option B has been on my todo list since removing the delay from the MCP driver and introducing the TX buffer check in the esp32can driver, as I
don't think applications should need to handle TX overflows.
I can try to implement that this weekend if it's urgent now.
Am 11.01.2018 um 05:55 schrieb Greg D.:
> Hi Mark, Micheal,
> Ok, good news and bad news.
> Good news: Rx problem I believe is fixed. Return is true only if we received something, else false. And the other interrupt conditions are
> handled at the same time, so no hangs are seen when restarting wifi. Rx overflow counter does increment properly. Yea! Code has been pushed
> to my clone on Github.
> Bad news: I am still able to hang the bus, but I think it's on the transmit side. The obd2ecu process can send up to 3 frames back to back
> to report the ECU Name, followed soon after by several more with to grab the VIN. Without any flow control on the transmit side, and with a
> half-duplex CAN bus, that's just too much. Turning off the VIN reporting (config set obd2ecu private yes) seems to let everything run because
> I don't respond to the VIN request (which lets everything drain as OBDWiz times out). Also verified by putting temporary delays in the
> obd2ecu code to let things drain a bit between frames. So, the transmit side is still a bit fragile, depending on timing. Not sure quite
> what to do here, as there is no easy place to queue things... Do we need to go back to the old way with a delay in the obd2ecu code (perhaps
> better than in the driver, no?). Architecturally it's ugly, but this only occurs at startup, and I don't mind the kludge. Do any other uses
> of the MCP busses do a burst of transmitting? If not, I'll put the delays in the obd2ecu code and call it close enough. Lemme know.
> For receive, I'd go with what I have for now, if Michael would be so kind as to review what I have done first.
> https://github.com/bitsofgreg/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/mcp2515/mcp2515.cpp Hopefully he'll be
> back on line before I get up in the morning. Wonderful how the Earth's spin helps with the teamwork.
> I'll keep poking at things tonight, and take it out for a spin in the car tomorrow, just to see everything working together. But as it is
> now, it's much better than it was before. Really, this time. :)
> Greg
> Greg D. wrote:
>> Hi Mark,
>> I believe you are right about the multiple flags, and the code only processing Rx and "error" separately. Fundamentally, a roll-over from
>> buffer 0 to buffer 1 isn't really an error, just a statement of fact on what happened. So, we should have buffer 1 and the rollover flag at
>> the same time, which in fact is what I saw. I need to handle the Rx overflow at the same time as the buffer 1 receive, I think...
>> I need to grab some dinner, but have a fix in the works. Will report back in a few hours, hopefully with good news...
>> Greg
>> Mark Webb-Johnson wrote:
>>> The design of the system is as follows:
>>> * The can object CAN_rxtask listens on the rx queue to receive instructional messages from canbus drivers. These can be:
>>> o CAN_frame: simply passes an entire incoming can frame to the IncomingFrame handler.
>>> o CAN_rxcallback: an instruction for the CAN_rxtask to call the RxCallback task repeatedly.
>>> o CAN_txcallback: an instruction for the CAN_rxtask to call the TxCallback once.
>>> * In the case of CAN_rxcallback, the canbus object RxCallback function is expected to return FALSE to indicate nothing should be done and
>>> RxCallback should not be called again, or TRUE to indicate an incoming frame has been received and should be passed to IncomingFrame.
>>> * The system is arranged so that individual bus driver interrupt implementations can be fast and efficient.
>>> o The driver can choose to receive the frame in the interrupt handler itself, and pass it with CAN_frame to CAN_rxtask. The esp32 can
>>> driver uses this option.
>>> o Or the driver can choose to delay the reception of the frame to the RxCallback stage, and merely pass an indication with
>>> CAN_rxcallback. The mcp2515 driver uses this option.
>>> * The true/false response from RxCallback is designed to allow the callback to signal it received a frame or not. If it received a frame,
>>> then it is called again.
>>> * This approach is used in order to be able to centralise the reception of CAN frames to one single task (avoiding having to run
>>> individual tasks for each canbus, hence saving stack RAM).
>>> The RxCallback should definitely ONLY return true if an actual can message has been received, and is being passed back in the frame pointer
>>> parameter.
>>> I suspect the issue is that the mcp2515 RxCallback is being faced with multiple error flags. Changing that to a return true (as Greg has
>>> done) has the undesired side-effect of issuing a spurious IncomingFrame (with garbage/blank frame), but also causes the RxCallback to be
>>> called again (clearing the error flag). Perhaps the solution is to put a loop in RxCallback so that if an error condition is found, it
>>> should be cleared, but then loop again and keep clearing errors until no more are found, then return false? I think that in the mcp2515
>>> case, this error clearing loop can be simply handled in the RxCallback itself.
>>> The alternative is to change the RxCallback logic so that the return bool value means simply ‘loop’ (call me again, please), and have the
>>> RxCallback itself call IncomingFrame(), rather than passing a frame as a parameter. If Michael/Greg think this is a better approach, I am
>>> happy to make that change - it is pretty trivial.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180111/153f4212/attachment.htm>
