[Ovmsdev] Add support for "log file ..." to log to the specified vfs file
Wed Jan 10 20:54:50 HKT 2018
Mark, Steve,
thanks for the test & workaround.
Yes, the syslog can better be distributed internally by the console system. The "tail" command is also intended for general debugging/monitoring
of files. I thought it would be straight forward to implement, but another issue/idea turned up we should discuss -- I'll follow up on that
after work.
Am 10.01.2018 um 01:07 schrieb Mark Webb-Johnson:
> Nope:
> Here is /store:
> OVMS > log file /store/log.txt
> I (37670) simcom: State: Enter PoweringOn state
> I (37670) simcom: Power Cycle
> OVMS > vfs stat /store/log.txt
> File /store/log.txt size is 0 and digest d41d8cd98f00b204e9800998ecf8427e
> OVMS > log file
> Closed log file
> File /store/log.txt size is 1176 and digest b15515a15edeb75d04a2767ba66a721d
> And here is /sd:
> OVMS > log file /sd/log.txt
> I (15494) simcom: State timeout, transition to 1
> I (15494) simcom: State: Enter CheckPowerOff state
> OVMS > vfs stat /sd/log.txt
> File /sd/log.txt size is 0 and digest d41d8cd98f00b204e9800998ecf8427e
> OVMS > log file
> Closed log file
> File /sd/log.txt size is 122 and digest ae18d2d2ed63b5dd2381b5bf11d1779d
> Seems to be the FAT filesystem itself.
> The vfs layer only seems to support a fsync operation, but no fflush. I’m guessing fflush just flushes the FILE buffers, but doesn’t actually
> sync that to disk. Adding 'fsync(fileno(ovms_log_file));’ after 'fflush(ovms_log_file);’ in ConsoleAsync::ConsoleLogger of
> main/console_async.cpp seems to resolve this:
> I (15450) simcom: State timeout, transition to 13
> I (15620) simcom: State: Enter PoweredOff state
> File /store/log.txt size is 1296 and digest 96221e6daf7258b6e2c0d9eb4a92cad3
> There is also a separate issue of multi-line messages not being logged correctly (LF -> “|" translation). I’ve pushed both fixes to
> the remotes/origin/for-v3.0 branch Steve and I are working on for v3.0. Haven’t tested in 2.1 master, but it will probably work there if you
> want to merge back to master.
> All that said, I think Steve is correct. A tail function (although useful) is not the best way of doing this particular thing. Better to have
> a ‘log monitor yes/no’ command that sets a flag on the current console (presumably in OvmsWriter like the m_issecure flag). If set, then log
> messages are shown on that console. Perhaps default to ‘yes’ for async console, and ‘no’ for the others.
> Now SD CARD support is coming, anybody want to step forward and extend components/can to support CAN bus logging to a file (in crtd format, or
> perhaps support one or two popular formats)? Implementation would be in class canbus, very similar to m_trace; just need to have a FILE* m_log
> and appropriate commands / logging of packet write/read in the same place that trace does it.
>> On 10 Jan 2018, at 7:28 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>> Michael,
>> I think we can do better than "tail" command. The design for printing
>> log messages is prepared to print on all registered consoles. We have
>> restricted the console_logger() function to just output on the async
>> console out of concernt that sending output to the remote consoles
>> might be too much of a burden. But if that is what's desired for a
>> particular user's scenario, then what we should do is to add a command
>> to direct the output to all consoles.
>> -- Steve
>> On Wed, 10 Jan 2018, Michael Balzer wrote:
>>> Mark,
>>> I've built a simple "tail" command to follow the file log on the telnet console.
>>> Unfortunately -- with v2.1 -- the fflush() on the log file doesn't work as expected, the file contents will not be updated until I close the
>>> file.
>>> Is that issue solved with v3.x?
>>> Am 08.01.2018 um 07:28 schrieb Mark Webb-Johnson:
>>>> I've restructured the log commands a bit:
>>>> * The old "level <severity>" command has moved to "log level <severity>"
>>>> * A new "log file <path>" command has been added. For example "log file /sd/log.txt" will mean that anything that gets logged to the
>>>> console will also get
>>>> appended to /sd/log.txt as well, until reboot. You can use /sd (if SD CARD is working for you), or /store (but take care - that is
>>>> system flash).
>>>> * You should be able to hook this in at the "sd.mounted" event script, to turn on logging to sd card on boot (again, if SD CARD is working
>>>> for you).
>>>> Enjoy, Mark
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180110/901254bc/attachment.htm>
