[Ovmsdev] Add support for "log file ..." to log to the specified vfs file
Wed Jan 10 07:20:16 HKT 2018
Mark,
I've built a simple "tail" command to follow the file log on the telnet console.
Unfortunately -- with v2.1 -- the fflush() on the log file doesn't work as expected, the file contents will not be updated until I close the file.
Is that issue solved with v3.x?
Am 08.01.2018 um 07:28 schrieb Mark Webb-Johnson:
> I’ve restructured the log commands a bit:
> * The old "level <severity>” command has moved to "log level <severity>"
> * A new “log file <path>” command has been added. For example “log file /sd/log.txt” will mean that anything that gets logged to the console will also get
> appended to /sd/log.txt as well, until reboot. You can use /sd (if SD CARD is working for you), or /store (but take care - that is system flash).
> * You should be able to hook this in at the “sd.mounted” event script, to turn on logging to sd card on boot (again, if SD CARD is working for you).
> Enjoy, Mark
>> Branch: refs/heads/master
>> Home: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3
>> Commit: 6947670e33823dd68d4bf76b7872518fc8398264
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/6947670e33823dd68d4bf76b7872518fc8398264
>> Author: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>> Date: 2018-01-08 (Mon, 08 Jan 2018)
>> Changed paths:
>> M vehicle/OVMS.V3/main/console_async.cpp
>> M vehicle/OVMS.V3/main/ovms_command.cpp
>> M vehicle/OVMS.V3/main/ovms_log.h
>> M vehicle/OVMS.V3/main/ovms_main.cpp
>> Log Message:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180110/34c2b9e9/attachment.htm>
