[Ovmsdev] WiFi mode off reboot
Tue Jan 9 04:27:00 HKT 2018
Fixed.
Caused by a scan result coming in after switching off wifi.
(Todo: replace remaining ESP_ERROR_CHECKs in the Wifi module by real error handling)
Am 08.01.2018 um 08:24 schrieb Greg D.:
> Hi folks,
> Another crash. Not repeatable, but wanted to report it before I head up
> stairs to end the day.
> I had booted the module, modem off, obdii ecu started, v2 server enabled
> but not connected. Wifi was started but the local network is hidden, so
> it wasn't connected. This is all in the startup event script. OBDWiz
> dongle running, all fine. The plan was to let it run for the night, to
> catch any longer-term reboots, so I needed to turn off the wifi in order
> to keep the screen from filling up with 'incorrect scan type' messages.
> Hit wifi mode off, and it crashed (see below). Doesn't appear to be a
> memory issue. Tried it a second time, and wifi stopped as normal.
> {sigh} Definitely time for bed...
> Greg
> OVMS > wifi mode off
> Stopping wifi station...
> ESP_ERROR_CHECK failed: esp_err_t 0x3002 at 0x400d6945
> 0x400d6945:
> _ZN9esp32wifi17EventWifiScanDoneENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEPv
> at
> /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/esp32wifi/./esp32wifi.cpp:462
> (discriminator 1)
> file:
> "/home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/esp32wifi/./esp32wifi.cpp"
> line 462
> func: void esp32wifi::EventWifiScanDone(std::__cxx11::string, void*)
> expression: esp_wifi_scan_get_ap_records(&apCount, list)
> Backtrace: 0x40088810:0x3ffbb580 0x40088b8d:0x3ffbb5a0
> 0x400d6945:0x3ffbb5c0 0x400d75d8:0x3ffbb690 0x40101965:0x3ffbb6d0
> 0x40101bbe:0x3ffbb700 0x40101c61:0x3ffbb750 0x40102089:0x3ffbb9a0
> 0x4013e991:0x3ffbb9c0 0x4013e9d5:0x3ffbb9e0
> 0x40088810: invoke_abort at
> /home/greg/esp/esp-idf/components/esp32/./panic.c:519
> 0x40088b8d: _esp_error_check_failed at
> /home/greg/esp/esp-idf/components/esp32/./panic.c:531
> 0x400d6945:
> at
> (discriminator 1)
> 0x400d75d8:
> _ZNKSt12_Mem_fn_baseIM9esp32wifiFvNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEPvELb1EEclIJS6_S7_EvEEvPS0_DpOT_
> at
> /home/greg/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600
> (inlined by)
> _ZNSt5_BindIFSt7_Mem_fnIM9esp32wifiFvNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEPvEEPS1_St12_PlaceholderILi1EESD_ILi2EEEE6__callIvJOS7_OS8_EJLj0ELj1ELj2EEEET_OSt5tupleIJDpT0_EESt12_Index_tupleIJXspT1_EEE
> at
> /home/greg/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:1074
> (inlined by)
> _ZNSt5_BindIFSt7_Mem_fnIM9esp32wifiFvNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEPvEEPS1_St12_PlaceholderILi1EESD_ILi2EEEEclIJS7_S8_EvEET0_DpOT_
> at
> /home/greg/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:1133
> (inlined by)
> _ZNSt17_Function_handlerIFvNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEPvESt5_BindIFSt7_Mem_fnIM9esp32wifiFvS5_S6_EEPSA_St12_PlaceholderILi1EESF_ILi2EEEEE9_M_invokeERKSt9_Any_dataOS5_OS6_
> at
> /home/greg/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:1871
> 0x40101965:
> _ZNKSt8functionIFvNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEPvEEclES5_S6_
> at
> /home/greg/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271
> 0x40101bbe:
> _ZN10OvmsEvents11SignalEventENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEPv
> at
> /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_events.cpp:144
> 0x40101c61: _ZN10OvmsEvents17SignalSystemEventEP14system_event_t at
> /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_events.cpp:167
> 0x40102089: _ZN10OvmsEvents18ReceiveSystemEventEPvP14system_event_t at
> /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_events.cpp:155
> 0x4013e991: esp_event_post_to_user at
> /home/greg/esp/esp-idf/components/esp32/./event_loop.c:94
> 0x4013e9d5: esp_event_loop_task at
> Rebooting...
