[Ovmsdev] Macros MIN and MAX
Fri Jan 5 23:53:14 HKT 2018
I sent a pull request with newest version for the Kia Soul. Have removed MIN and MAX and uses sys/param.h instead.
Geir
> 5. jan. 2018 kl. 02:05 skrev Mark Webb-Johnson <mark at webb-johnson.net>:
> Three reasons for working on IDF 3.0 now:
> We’ll need it for PSRAM support, should we go that route.
> It is the latest bootloader, and includes firmware checksum support (it is hard to OTA update the bootloader).
> If Espressif fix the SDCARD issue (assuming it is fixable in software), they will most likely fix it in that branch.
> We’re still working with Espressif on SDCARD vs flash >4MB. Response is less than exciting. They made a board to try to recreate the problem, but put a 4MB flash on it and not surprisingly couldn’t repeat the issue. We keep telling them to try with a 16MB flash, but it is like talking to a brick wall. Or perhaps a brick wall at the other end of a pitch black room with no echo. Very frustrating.
> <test_board.jpeg>
>> On 5 Jan 2018, at 5:20 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Stephen,
>> sys/param.h was not included previously. As the definitions match, I can use those. Or add an #ifndef / #undef.
>> As you're compiling with v3 already: are the SD card issues solved with that release?
>> Am 04.01.2018 um 22:01 schrieb Stephen Casner:
>>> Michael and Geir,
>>> Can you please see whether the definitions of MIN and MAX in your
>>> files are needed?  These macros are defined in:
>>> esp-idf/components/newlib/include/sys/param.h
>>> which gets included from ovms_config.h and perhaps other places.
>>> When I'm compiling with release v3.0 the redefinition of these macros
>>> shows up as a warning.  It would be possible to ignore the warning and
>>> it might also be possible to turn off the warnings by changing the
>>> configuration, but if the definitions are not needed this would be
>>> cleaner.
>>>                                                        -- Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180105/c42a0cfb/attachment.htm>
