Mon Jan 29 08:29:06 HKT 2018
I suspect that this is timing related:
OVMS > wifi mode client XXX
Starting WIFI as a client to XXX…
I (337100) ssh: Launching SSH Server
V (338830) ssh: Event MG_EV_ACCEPT conn 0x3ffee8b4, data 0x3ffee8cc
V (338840) ssh: Event MG_EV_RECV conn 0x3ffee8b4, data received 21
V (338840) ssh: Event MG_EV_SEND conn 0x3ffee8b4, data 0x3ffe5d90
V (338840) ssh: Event MG_EV_RECV conn 0x3ffee8b4, data received 1024
V (338850) ssh: Event MG_EV_RECV conn 0x3ffee8b4, data received 408
OVMS > wifi mode off
Stopping wifi station...
I (350580) ovms-mdns: Stopping MDNS service
I (350580) wifi: state: run -> init (0)
I (350590) wifi: pm stop, total sleep time: 0/11930449
I (350590) wifi: n:11 0, o:11 0, ap:255 255, sta:11 0, prof:1
I (350600) wifi: flush txq
I (350600) wifi: stop sw txq
I (350600) wifi: lmac stop hw txq
I (350600) wifi: Deinit lldesc rx mblock:4
I (351340) webserver: Stopping Web Server
I (351340) ssh: Stopping SSH Server
V (351540) ssh: Event MG_EV_CLOSE conn 0x3ffee8b4, data 0x0
V (351540) ssh: Event MG_EV_CLOSE conn 0x3ffeb468, data 0x0
I (357570) event: station ip lost
But ssh client connection is still up on my workstation. Looks like the MG_EV_CLOSE events came in after the SSH server was stopped.
I repeated the test, but with event logging on:
I (34171) events: Signal(system.wifi.down)
I (34171) events: Signal(network.wifi.down)
I (34171) ovms-mdns: Stopping MDNS service
I (34171) events: Signal(network.reconfigured)
I (34171) events: Signal(network.down)
I (34171) wifi: state: run -> init (0)
I (34181) wifi: pm stop, total sleep time: 0/9603569
I (34181) wifi: n:11 0, o:11 0, ap:255 255, sta:11 0, prof:1
I (34191) wifi: flush txq
I (34191) wifi: stop sw txq
I (34191) wifi: lmac stop hw txq
I (34191) wifi: Deinit lldesc rx mblock:4
I (34191) events: Signal(system.wifi.sta.disconnected)
I (34191) events: Signal(system.wifi.sta.stop)
I (35131) events: Signal(network.mgr.stop)
I (35131) webserver: Stopping Web Server
I (35131) ssh: Stopping SSH Server
V (35331) ssh: Event MG_EV_CLOSE conn 0x3ffec138, data 0x0
V (35331) ssh: Event MG_EV_CLOSE conn 0x3ffeb768, data 0x0
MDNS exits quicker because it responds to the network.wifi.down message, while ssh uses the network.mgr.stop event. In a clean shutdown there is a difference.
Perhaps we should issue network.mgr.stop earlier? However, even if we close the connections from our end, I’m not sure if the packet would make it through to the other end before the wifi disconnects.
> On 29 Jan 2018, at 2:13 AM, Stephen Casner <casner at acm.org> wrote:
> I handled wifi shutdowns cleanly when I first implemented telnet and
> ssh as their own tasks. Now that they are under Mongoose, it is out
> of my control. The socket is owned by the Mongoose code.
> -- Steve
> On Sun, 28 Jan 2018, Michael Balzer wrote:
>> I've begun working on the webserver and noticed something that may
>> be correlated to this: sockets don't get closed when losing the
>> connection. The effect is visible on both web and telnet server (ssh
>> not tested). To reproduce, switch the Wifi network with an open
>> connection, the port will not be available until timeout.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180129/ba55577a/attachment.html>
