[Ovmsdev] What is the format of ms_v_charge_timerstart?
Tue Jan 23 08:12:14 HKT 2018
It is the car. This setting (ms_v_charge_timerstart) is paired with ms_v_charge_timermode to indicate the car is in timer mode (ie; will start charging at a specific time of day, rather than immediately on plug-in).
For car’s that don’t have charge timers, we could directly support them within OVMS. Not too hard to do (if ms_v_charge_timermode AND ms_v_charge_pilot AND ms_v_charge_timerstart is now, then start charge). But, we would need a command to be able to remotely set this timer mode.
> On 23 Jan 2018, at 6:00 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Is it the car or the OVMS system that actually starts the charge? Just wondering if we have a car dependency here.
> Greg
> p.s. to Geir... It's kind of fitting that an email about time would arrive 11 minutes prior to its time stamp. Is your PC's clock set right?
> Geir Øyvind Vælidalo wrote:
>> Number of minutes after midnight (UTC) would be great.
>> Best regards,
>> Geir
>>> 22. jan. 2018 kl. 03:51 skrev Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>>> My notes have it as a Tesla Roadster message:
>>> (gmthour*60)-1, with special case midnight gmthour=24
>>> N.B. Empirical values for TimerLSB and TimerMSB (a GMT+0800 car in Hong Kong) are:
>>> 1439 (0x059F) for midnight GMT, 59 (0x003B) for 1am GMT, up to 1379 (0x0563) for 11pm GMT.
>>> Kind of ugly, and never properly declared/used. It is sent back to the server/apps, but I don’t think it was ever used.
>>> I’m happy for it to be the number of minutes after midnight (UTC) when timed charge should start.
>>>> On 21 Jan 2018, at 8:41 PM, Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>> wrote:
>>>> Hi,
>>>> What is the format of ms_v_charge_timerstart? I can’t find any info about it anywhere...
>>>> Best regards,
>>>> Geir
>>>> OvmsDev mailing list
>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180123/28f46f4e/attachment.html>
