[Ovmsdev] Transition to new esp-idf
Fri Jan 19 22:08:35 HKT 2018
Tried & kept :)
With vehicle module running, connectivity _and_ SD card mounted, I now have
OVMS > module memory
Free 8-bit 46200/285768, 32-bit 17948/45120, SPIRAM 0/0
Great find. I hope that won't affect SD write performance too badly.
While testing I found a bug: after a manual "sd unmount" I get lots of
E (121106) sdmmc_req: handle_idle_state_events unhandled: 00000008 00000002
…and new mounts afterwards won't work.
Am 19.01.2018 um 01:39 schrieb Mark Webb-Johnson:
> Michael: Can you try menuconfig Component / FAT Filesystem support / Use separate cache for each file -> OFF. Documentation shows that controlling the FS_TINY
> flag (which sounds like something we want).
> With wifi, DEMO vehicle module, sd mounted, and server v2 running, I get:
> Free 8-bit 70136/282488, 32-bit 17660/44832, SPIRAM 0/0
> OVMS > sd unmount
> Free 8-bit 77604/282488, 32-bit 17660/44832, SPIRAM 0/0
> --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM
> tiT 356 1088 0 0 +16 -20 +0 +0
> Tmr Svc 20 528 0 0 -860 -6444 +0 +0
> Using “separate cache for each file”, I get:
> Free 8-bit 29156/282496, 32-bit 17660/44832, SPIRAM 0/0
> OVMS > sd unmount
> Free 8-bit 57096/282496, 32-bit 17660/44832, SPIRAM 0/0
> Tmr Svc 0 552 0 0 -4 -27780 +0 +0
> Seems to be 27KB vs 7KB per filesystem mount, and we have two (/sd and /store). Overall win with FS_TINY for FAT is close to 41KB.
>> On 17 Jan 2018, at 9:23 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> Note also that the memory debugging option adds a bit of overhead.
>> With debugging enabled (heap: light impact):
>> Free 8-bit 79868/282496, 32-bit 17660/44832, SPIRAM 0/0
>> no task 5312 0 0 0 +5312 +0 +0 +0
>> esp_timer 49568 0 644 0 +49568 +0 +644 +0
>> main 39444 0 0 0 +39444 +0 +0 +0
>> ipc0 11096 0 0 0 +11096 +0 +0 +0
>> Housekeeping 24740 19956 0 0 +24740 +19956 +0 +0
>> tiT 132 0 0 0 +132 +0 +0 +0
>> Tmr Svc 4 27800 0 0 +4 +27800 +0 +0
>> ipc1 12 0 0 0 +12 +0 +0 +0
>> AsyncConsole 0 36 26404 0 +0 +36 +26404 +0
>> OVMS > metrics list m.freeram
>> m.freeram 79868
>> With debugging enabled (heap: comprehensive):
>> Free 8-bit 79728/282320, 32-bit 17968/45140, SPIRAM 0/0
>> Housekeeping 24644 20056 0 0 +24644 +20056 +0 +0
>> AsyncConsole 0 20 26404 0 +0 +20 +26404 +0
>> I (15614) simcom: State timeout, transition to 13
>> I (15614) simcom: State: Enter PoweredOff state
>> m.freeram 79728
>> With debugging disabled:
>> To use these debugging tools, must set CONFIG_HEAP_TASK_TRACKING=y
>> and have updated openvehicles/esp-idf
>> m.freeram 99956
>> I think we’ve still got some stuff we can look at to lighten the impact on internal memory. Once we can get the 3.1 hardware out, I can focus on that. The
>> memory tools Steve has built are really complete and usable now. They let us see exactly what is going on.
>> If we had known going in that the 520KB SRAM of the ESP32 would be 80% used by the system, and only 20% for us, perhaps things would have been done
>> differently. Anyway, we are where we are, and the WROVER module should be able to move a bunch of stuff off to PSRAM.
>>> On 17 Jan 2018, at 12:59 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Bluetooth is disabled. Has been for a while, I don't see a chance to enable it with the 3.0 module.
>>> I've also disabled Javascript support (duktape), Wolf, the web server and MDNS and the OBD2ECU. Telnet is enabled as I sometimes use that parallel to the
>>> async console.
>>> That config gives me…
>>> Free 8-bit 117364/286352, 32-bit 17972/45144, SPIRAM 0/0
>>> …after reboot (without SD card), and with Wifi, modem, Twizy & server v2 running & connected…
>>> Free 8-bit 23436/286352, 32-bit 17972/45144, SPIRAM 0/0
>>> …when idle, will drop further with transmissions pending etc.
>>> Opening a telnet session then results in:
>>> Free 8-bit 18372/286352, 32-bit 17972/45144, SPIRAM 0/0
>>> …and still stable.
>>> Am 16.01.2018 um 01:11 schrieb Mark Webb-Johnson:
>>>> I’m seeing this:
>>>> Free 8-bit 79812/282268, 32-bit 17816/44988, SPIRAM 0/0
>>>> OVMS > sd unmount
>>>> Unmounted SD CARD
>>>> Free 8-bit 107768/282268, 32-bit 17816/44988, SPIRAM 0/0
>>>> Tmr Svc 0 20 0 0 -4 -27780 +0 +0
>>>> I guess it is FAT fs stuff, but we use that for /store as well so not sure why so much. I will look into it.
>>>> With wifi client, ovms server v2, tesla roadster vehicle module, I get this:
>>>> Free 8-bit 54224/282268, 32-bit 17816/44988, SPIRAM 0/0
>>>> With the OBDII HUD, that drops to 45KB.
>>>> Do you have bluetooth enabled (in menuconfig)?
>>>> Regards, Mark.
>>>>> On 16 Jan 2018, at 3:35 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>> I've found the missing RAM. It's allocated for the SD card:
>>>>> I (34235) sdcard: SD CARD has been inserted. Auto-mounting...
>>>>> Free 8-bit 89348/286352, 32-bit 17972/45144, SPIRAM 0/0
>>>>> Tmr Svc 4 27804 0 0 +4 +27804 +0 +0
>>>>> I (68065) sdcard: SD CARD has been removed.
>>>>> Free 8-bit 117332/286352, 32-bit 17972/45144, SPIRAM 0/0
>>>>> Tmr Svc 0 12 0 0 -4 -27792 +0 +0
>>>>> …again…
>>>>> I (114985) sdcard: SD CARD has been inserted. Auto-mounting...
>>>>> Tmr Svc 4 27804 0 0 +4 +27792 +0 +0
>>>>> E (141205) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x107
>>>>> E (141205) diskio_sdmmc: sdmmc_read_blocks failed (263)
>>>>> I (141515) sdcard: SD CARD has been removed.
>>>>> Btw, I think the RAM usage of the telnet server is also higher than before:
>>>>> OVMS > wifi mode client
>>>>> Starting WIFI as a client for any defined SSID
>>>>> I (380175) wifi: wifi firmware version: 403db1d
>>>>> I (380175) wifi: config NVS flash: enabled
>>>>> I (380175) wifi: config nano formating: disabled
>>>>> I (380185) wifi: Init dynamic tx buffer num: 16
>>>>> I (380185) wifi: Init data frame dynamic rx buffer num: 16
>>>>> I (380185) wifi: Init management frame dynamic rx buffer num: 16
>>>>> I (380185) wifi: wifi driver task: 3ffe3db4, prio:23, stack:4096
>>>>> I (380185) wifi: Init static rx buffer num: 4
>>>>> I (380185) wifi: Init dynamic rx buffer num: 16
>>>>> I (380195) wifi: wifi power manager task: 0x3ffe846c prio: 21 stack: 2560
>>>>> I (380195) wifi: mode : sta (30:ae:a4:37:25:88)
>>>>> W (390205) wifi: incorrect scan type: 1073534024
>>>>> I (392615) esp32wifi: Found SSID devolo-f4068d73a03e - trying to connect
>>>>> I (393945) wifi: n:11 2, o:1 0, ap:255 255, sta:11 2, prof:1
>>>>> I (394595) wifi: state: init -> auth (b0)
>>>>> I (394605) wifi: state: auth -> assoc (0)
>>>>> I (394605) wifi: state: assoc -> run (10)
>>>>> I (394625) wifi: connected with devolo-f4068d73a03e, channel 11
>>>>> I (394665) esp32wifi: WiFi UP with SSID: devolo-f4068d73a03e, MAC: 30:ae:a4:37:25:88, IP: 192.168.2.101, mask: 255.255.255.0, gw: 192.168.2.1
>>>>> I (394665) telnet: Launching Telnet Server
>>>>> I (397615) wifi: pm start, type:0
>>>>> Free 8-bit 89700/286352, 32-bit 17972/45144, SPIRAM 0/0
>>>>> tiT 128 716 0 0 +0 +484 +0 +0
>>>>> AsyncConsole 0 16552 26404 0 +0 +16356 +0 +0
>>>>> NetManTask 8 488 0 0 +8 +488 +0 +0
>>>>> wifi 0 1600 0 0 +0 +1600 +0 +0
>>>>> eventTask 0 7564 0 0 +0 +7564 +0 +0
>>>>> …but I'm not sure about that, haven't tested that in a while.
>>>>> So, SD cards now work, and I'll not be able to use them due to the RAM usage… :(
>>>>> Am 15.01.2018 um 19:21 schrieb Michael Balzer:
>>>>>> Transition went fine. "make flash" didn't even erase "/store", I had expected that to happen, good to know.
>>>>>> And…
>>>>>> OVMS > sd status
>>>>>> SD CARD is inserted
>>>>>> Type: SDHC/SDXC
>>>>>> Speed: default speed
>>>>>> CSD: ver=1, sector_size=512, capacity=62333952 read_bl_len=9
>>>>>> SCR: sd_spec=2, bus_width=5
>>>>>> → me too (the minion) :)
>>>>>> BUT… after reconfiguration to the same components as before, I'm now missing about 30-40 KB of free RAM.
>>>>>> After loading just the Twizy module & the v2 server, I'm now again down to…
>>>>>> Free 8-bit 2632/286352, 32-bit 17972/45144, SPIRAM 0/0
>>>>>> …so it crashes as soon as it needs to actually do anything, like sending a notification.
>>>>>> This is without any of the new CAN logging stuff yet, that's stashed away for the transition.
>>>>>> I'll now check the config again for any more options to save RAM…
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 15.01.2018 um 06:48 schrieb Stephen Casner:
>>>>>>> In order for the the "module memory" and "module tasks" commands to
>>>>>>> work, the configuration needs to be changed from the sdk.default.hw30
>>>>>>> that Mark just provided. CONFIG_FREERTOS_USE_TRACE_FACILITY needs to
>>>>>>> be enabled, CONFIG_HEAP_POISONING must be enabled (LIGHT or
>>>>>>> COMPREHENSIVE), and CONFIG_HEAP_TASK_TRACKING must be enabled. I have
>>>>>>> attached a diff for the sdkconfig. That diff also includes a section
>>>>>>> for enabling telnet, which some of you may be using.
>>>>>>> Please also note that in this revised implementation of "module
>>>>>>> memory" the block address is now the address that is returned from
>>>>>>> malloc, not the address of the header that precedes it, and the length
>>>>>>> of the block is now exclusive of the debugging overhead.
>>>>>>> -- Steve
>>>>>>> On Mon, 15 Jan 2018, Mark Webb-Johnson wrote:
>>>>>>>> All committed and pushed now.
>>>>>>>> Developers MUST now update their ESP IDF and XTENSA build tools to use this new build. They should also compare sdkconfig and sdkconfig.defaults.hw30 to verify differences. I also suggest you do a ‘make flash’ (rather than ‘make app-flash’) at least once, to update the bootloader to the latest (as bootloaders before v2.1 are no longer supported).
>>>>>>>> Check
>>>>>>>> https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain>
>>>>>>>> to see the version of XTENSA toolchain required for latest Espressif IDF ‘master’ builds. As of this writing, it is 1.22.0-80-g6c4433a-5.2.0.
>>>>>>>> I hope this goes smoothly for you.
>>>>>>>> Regards, Mark.
>>>>>>>> commit dfcc658557fc480bcccb09b23bc24399bb6e7497 (HEAD -> master, origin/master, origin/HEAD)
>>>>>>>> Author: Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net>
>>>>>>>> Date: Mon Jan 15 07:56:45 2018 +0800
>>>>>>>> Provide a sdkconfig.default.hw31 for OVMS v3.1 hardware
>>>>>>>> commit 003592d553c881f735fb228b08836a13c306cec3
>>>>>>>> Merge: e58c5b6 b28db5e
>>>>>>>> Date: Mon Jan 15 07:49:13 2018 +0800
>>>>>>>> Merge branch 'for-master'. This requires ESP-IDF v3.0 support:
>>>>>>>> OVMS developers should now:
>>>>>>>> 1] Pull the latest OpenVehicles IDF, and checkout MASTER branch.
>>>>>>>> 2] Update XTENSA tools to match version required by Espressif for MASTER branch.
>>>>>>>> 3] For ovms hardware v3.0, a sdkconfig default file sdkconfig.default.hw30 has
>>>>>>>> been provided. That can be merged/copied to sdkconfig as appropriate.
>>>>>>>> 4] For ovms hardware v3.1, a sdkconfig default file sdkconfig.default.hw31 will
>>>>>>>> been provided in the next update.
>>>>>>>> 5] It is recommended that developers perform at least one full 'make flash'
>>>>>>>> with this version, to update the bootloader to latest. Note that the
>>>>>>>> sdkconfig.default.* files are now set to require bootloader at least v2.1
>>>>>>>> (or later), and bootloader v2.0 is no longer supported.
>>>>>>>> Enjoy.
>>>>>>>>> On 15 Jan 2018, at 7:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net> wrote:
>>>>>>>>> Merge is ok, but triple checking a couple of things. Should be committed and pushed within the next half hour.
>>>>>>>>> Regards, Mark
>>>>>>>>>> On 15 Jan 2018, at 1:09 AM, Stephen Casner <casner at acm.org> <mailto:casner at acm.org> wrote:
>>>>>>>>>> Mark,
>>>>>>>>>> It looks like you were not able to do the sdkconfig.default and merge
>>>>>>>>>> as you planned?
>>>>>>>>>> -- Steve
>>>>>>>>>>> On Fri, 12 Jan 2018, Stephen Casner wrote:
>>>>>>>>>>>> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
>>>>>>>>>>>> @Steve can you update our master clone to latest from Espressif and
>>>>>>>>>>>> make sure your stuff is still ok?
>>>>>>>>>>> I have just now done this. I had already done a rebase a few days ago
>>>>>>>>>>> before committing the improved version of the OS changes so I could
>>>>>>>>>>> issue a pull request. There were a few commits since then, which I
>>>>>>>>>>> have now merged. My code still runs correctly.
>>>>>>>>>>>> I guess steps for developers will be:
>>>>>>>>>>>> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
>>>>>>>>>>>> 2) download and install xtensa build chain to match.
>>>>>>>>>>>> 3) update OVMS master, make clean, check menu config, then build and play.
>>>>>>>>>>> Sounds right.
>>>>>>>>>>>> I can get my part done by Sunday 14th night (HKT), so suggest to do
>>>>>>>>>>>> the Merge of the OVMS firmware master branch then.
>>>>>>>>>>> I'll be sleeping then, so you can go ahead and do the merge.
>>>>>>>>>>> -- Steve
>>>>>>>>>> _______________________________________________
>>>>>>>>>> OvmsDev mailing list
>>>>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180119/b89ecf51/attachment-0001.html>
