[Ovmsdev] Transition to new esp-idf
    Fri Jan 19 15:22:35 HKT 2018
Oops. Sorry. That change broke MQTT. I couldn’t understand what was going on (as mg_send was sending immediately). MQTT works like this:
void mg_mqtt_publish(struct mg_connection *nc, const char *topic,
                     uint16_t message_id, int flags, const void *data,
                     size_t len) {
  size_t old_len = nc->send_mbuf.len;
  uint16_t topic_len = htons((uint16_t) strlen(topic));
  uint16_t message_id_net = htons(message_id);
  mg_send(nc, &topic_len, 2);
  mg_send(nc, topic, strlen(topic));
  if (MG_MQTT_GET_QOS(flags) > 0) {
    mg_send(nc, &message_id_net, 2);
  mg_send(nc, data, len);
  mg_mqtt_prepend_header(nc, MG_MQTT_CMD_PUBLISH, flags,
                         nc->send_mbuf.len - old_len);
It uses mg_send a bunch of times, then goes back and modifies the send_mbuf by inserting a header, then finishes so that the actual transmission can occur. Seems a really dumb way to do it, but such is life.
It was driving me crazy last night, so in the end I just updated mongoose this morning and hey! everything worked. Now I know why :-(
I see that mg_send_dns_query() does the same (it calls mg_dns_insert_header, which then calls mbuf_insert). Making mg_send transmit immediately would break that as well.
How about introducing a new mg_send_now() that calls mg_send() then sends the data immediately? Perhaps it could be a separate .h/.c file mongoose_extensions to avoid the change getting overwritten?
> On 19 Jan 2018, at 2:36 PM, Stephen Casner <casner at acm.org> wrote:
> Mark,
> The update of Mongoose to v6.10 removed the change I had made so that
> the mg_send() call would transmit on the network immediately if the
> socket was ready.  I needed to make that change because we would
> otherwise run out of RAM with SSH because mg_send() would just buffer
> everything until the next poll.
> On Fri, 19 Jan 2018, Mark Webb-Johnson wrote:
>> I re-worked the ovms_server_* framework, and v2 implementation, to use MONGOOSE.
>> It seems to be _basically_ working. It can connect/disconnect/etc. Some slight memory saving, but standardising the networking throughout on mongoose should simplify things.
>> I am seeing problems with transmitting the FEATURES and PARAMETERS sometimes - particularly in low memory situations. I’m still trying to find out why.
>>> On 17 Jan 2018, at 8:33 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> This is the issue Michael pointed out. The 'server response is incomplete’ problem with select(). Apologies for this; I am not sure why I didn’t notice it before.
>>> Gory details are here:
>>> https://github.com/espressif/esp-idf/issues/1510 <https://github.com/espressif/esp-idf/issues/1510>
>>> I think Espressif implemented requirement this in a bizarre way, likely to break compatibility, but such is life. They did point it out as a ‘breaking change’ (at the bottom of the release notes for 3.0b1):
>>> https://github.com/espressif/esp-idf/releases/tag/v3.0-rc1 <https://github.com/espressif/esp-idf/releases/tag/v3.0-rc1>
>>> LWIP socket file descriptors now take higher numeric values (via the LWIP LWIP_SOCKET_OFFSET macro). BSD sockets code should mostly work as expected (and, new in V3.0, some standard POSIX functions can now be used with sockets). However any code which assumes a socket file descriptor is always a low numbered integer may need modifying to account for LWIP_SOCKET_OFFSET.
>>> It sure broke us.
>>> I’ve made a one-line workaround fix (to ovms_buffer.cpp), and ovms server v2 connections are working again for me. That is committed and pushed already.
>>> It is kind of messy to have all these different networking implementations in our code base; I intend to move ovms_server_* to mongoose networking over the next few days. That will mean we won’t need a separate task/stack for server connections, and should save us 7KB internal RAM for each connection. Also ovms_ota. But that will have to wait, as I need to get the hardware complete first (some issues with 1.8v vs 3.3v logic on VDD_SDIO of the wrover module and some of our GPIOs), and that is top priority.
>>>> On 17 Jan 2018, at 7:05 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>> But, I'm not getting much love out of the v2 server.  The connection doesn't appear to be working - "server response is incomplete".  Same error whether on wifi or modem.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180119/9c1b9d58/attachment-0001.html>
