[Ovmsdev] CAN BUS logging to flash storage
Fri Jan 19 08:55:30 HKT 2018
Looks good to me. I can at least get traces logged.
Not sure about this, though:
Note: info logging is done at log level debug, frame logging at verbose
Is that the right way around? I haven’t got a can bus connected at the moment, so all I get is the errors shown (even on rx after a failed tx).
I’ll try it on a real bus, to see what it looks like there. Maybe if there are less errors, it would make more sense.
> On 19 Jan 2018, at 7:17 AM, Michael Balzer <dexter at expeedo.de> wrote:
> OK, first implementation is done & pushed. Documentation is missing, I'll add that ASAP.
> Basic usage:
> OVMS > can ?
> can1 CANx framework
> can2 CANx framework
> can3 CANx framework
> log CAN logging framework
> OVMS > can log ?
> crtd ...format logging
> off Stop logging
> status Logging status
> trace Logging to syslog
> OVMS > can log status
> CAN logging inactive.
> OVMS > can log trace ?
> Usage: can log trace [filter1] [filter2] [filter3]
> Filter: <bus> / <id>[-<id>] / <bus>:<id>[-<id>]
> Example: 2:2a0-37f
> OVMS > can log crtd ?
> Usage: can log crtd <path> [filter1] [filter2] [filter3]
> Example: 2:2a0-37f
> CAN logging active: Type:trace; Path:''; Filter:off; Vehicle:;
> OVMS > can can2 tx standard 201 12 34 56 11 22 33 44 55
> E (358776) canlog: Error can2 rxpkt=0 txpkt=1 errflags=0x8000 rxerr=63 txerr=0 rxovr=0 txovr=0 txdelay=0
> OVMS > can log off
> Closing log: Type:trace; Path:''; Filter:off; Vehicle:;
> CAN logging stopped.
> OVMS > can log crtd /sd/test.crtd 1 2:780-7ff
> CAN logging active: Type:crtd; Path:'/sd/test.crtd'; Filter:1:0-ffffffff,2:780-7ff; Vehicle:;
> OVMS > can can1 rx standard 100 12 34 56 11 22 33 44 55
> OVMS > can can1 tx standard 101 12 34 56 11 22 33 44 55
> OVMS > can can2 rx standard 200 12 34 56 11 22 33 44 55
> OVMS > can can2 rx standard 7d2 12 34 56 11 22 33 44 55
> OVMS > can can2 tx standard 7d3 12 34 56 11 22 33 44 55
> OVMS > can log off
> Closing log: Type:crtd; Path:'/sd/test.crtd'; Filter:1:0-ffffffff,2:780-7ff; Vehicle:;
> OVMS > vfs cat /sd/test.crtd
> 459.576 CXX Info Type:crtd; Path:'/sd/test.crtd'; Filter:1:0-ffffffff,2:780-7ff; Vehicle:;
> 476.706 1R11 100 12 34 56 11 22 33 44 55
> 480.366 1T11 101 12 34 56 11 22 33 44 55
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8000a6 rxerr=28 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8000a6 rxerr=37 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8000a6 rxerr=46 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8000a6 rxerr=55 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8000a6 rxerr=64 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8000a6 rxerr=73 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8000a6 rxerr=82 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x44000 rxerr=99 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8040a6 rxerr=100 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8040a6 rxerr=109 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8040a6 rxerr=118 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8040a6 rxerr=127 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x204000 rxerr=135 txerr=0 rxovr=0 txovr=0 txdelay=0
> 480.366 1CEV Error rxpkt=1 txpkt=1 errflags=0x8040a6 rxerr=135 txerr=0 rxovr=0 txovr=0 txdelay=0
> 522.616 2R11 7D2 12 34 56 11 22 33 44 55
> 522.616 2CEV TX_Queue T11 7D3 12 34 56 11 22 33 44 55
> Vehicle events are also logged, and if you issue "can <bus> status", the packet statistics will be logged.
> The crtd logger is fast enough for the (single bus) Twizy at 500 kbit without filters. I still have no means to test multiple buses.
> The current implementation limits the user to one active can logger, but that's just for ease of use and not fixed. We can add support for multiple parallel loggers, but I doubt there's an actual use case for this.
> Btw, as a next logger, we could implement the pcapng format: https://wiki.wireshark.org/Development/PcapNg <https://wiki.wireshark.org/Development/PcapNg>
> Am 14.01.2018 um 18:13 schrieb Michael Balzer:
>> Mark,
>> thanks for the info, I'll add a documentation file on this.
>> It just turned out writing into a file is far too slow to be done inline with the frame processing… and yes, I _could_ have anticipated that ;)
>> Maybe idf 3.x will perform better on file I/O, but a separate logging task is better anyway.
>> Am 12.01.2018 um 01:44 schrieb Mark Webb-Johnson:
>>> Thanks.
>>> I really should formally document the CRTD format properly somewhere. Anyway, here are my old notes on it, and an example:
>>> CRTD Example:
>>> 1320724293.000 CXX OVMS Tesla Roadster cando2crtd converted log
>>> 1320724293.000 CXX OVMS Tesla roadster log: trip.20111108.csv
>>> 1320724294.072 R11 420 00 96 96
>>> 1320724294.073 R11 588 00 00 86
>>> 1320724294.073 R11 280 00 00 03 00 00 00 00 00
>>> 1320724294.073 R11 001 00 00 00 00
>>> 1320724294.073 R11 590 01 00 00 00 00 00 00 00
>>> 1320724294.113 R11 400 01 01 00 00 00 00 4C 1D
>>> Generators should use whatever line termination the host system uses. For Unix and embedded systems that is LF. Parsers should support all CR, LF, and CRLF variants.
>>> Generators should output hex fields in upper-case and front zero padded (for clarity). Parsers should support both upper and lower case, as well as variable length.
>>> By convention, the .crtd extension is used for these files. It is suggested that generators prefix all crtd files with CXX lines documenting the generator, comment and source of log file.
>>> Space-separated fields are:
>>> Timestamp (can be seconds, milliseconds, or microseconds - zero prefixed and full length padded for ms and us).
>>> Type:
>>> C*: comment
>>> CXX: general comment (rest of line is a comment)
>>> CEV: user-generated event (rest of line is event description)
>>> R11: rx standard frame
>>> R29: rx extended frame
>>> T11: tx standard frame
>>> T29: tx extended frame
>>> Other field notes:
>>> For the R?? and T?? types, the rest of the line is hex ID followed by hex data bytes (up to 8).
>>> In the case of systems supporting multiple CAN buses, the type can be prefixed with the bus number (eg; 1R11, 2T29, etc). Messages from different CAN bus captures can be written to one shared crtd file, or individual files for each bus - entirely up to the generator.
>>>> On 11 Jan 2018, at 8:59 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>> Mark,
>>>> I'll add the logging support along with the TX queue.
>>>> Regards,
>>>> Michael
>>>> Am 10.01.2018 um 01:27 schrieb Mark Webb-Johnson:
>>>>> Probably best to split this off as a separate eMail thread.
>>>>> I think the implementation would be relatively simple.
>>>>> Create a canlog class with a FILE* m_log member variable, and a virtual function Log() that is called with a direction (tx/rx) and frame to log.
>>>>> The constructor should be passed the vfs file path to log to. It should fopen the m_log file to that.
>>>>> The destructor should fclose the m_log file.
>>>>> Create a canlog_crtd class, derived from canlog, that supports Log() to log to m_log in CRTD format.
>>>>> Optionally create other canlog_* classes, for other logging formats that we want to support.
>>>>> Add a canlog* m_log member variable in canbus.
>>>>> Initialise m_log to NULL in the constructor.
>>>>> In the destructor, if m_log is not null, delete it’s object and set it to NULL.
>>>>> Have a command ‘can log’ like ‘can trace’ that specifies a vfs file path (remember to check it with OvmsConfig ProtectedPath) and logging format. It will then ’new’ a canlog_* style object (depending on logging format).
>>>>> In can::IncomingFrame, log incoming CAN messages with m_log->Log(), in the same way as m_trace is handled.
>>>>> In canbus::Write, log outgoing CAN messages with m_log->Log(), in the same way as m_trace is handled.
>>>>> Volunteer?
>>>>> Regards, Mark.
>>>>>> On 10 Jan 2018, at 8:07 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>>> Now SD CARD support is coming, anybody want to step forward and extend components/can to support CAN bus logging to a file (in crtd format, or perhaps support one or two popular formats)? Implementation would be in class canbus, very similar to m_trace; just need to have a FILE* m_log and appropriate commands / logging of packet write/read in the same place that trace does it.
>>>>> OvmsDev mailing list
>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180119/eb41f1bd/attachment-0001.html>
