[Ovmsdev] Special cable for Kia Soul EV for OVMS V3.
Jason Perkins
perkins.jason at gmail.com
Tue Jan 16 21:09:16 HKT 2018
On the Fiat the OBD connector is "upside down" and faces forward, I've not
investigated turning it over. A cable opposite the one pictured above, with
a left edit, would be better. The cable would go to the middle of the cabin
and be tied up behind the trim.
Image borrowed from the forums:
[image: Inline image 2]
On Tue, Jan 16, 2018 at 1:19 AM, Geir Øyvind Vælidalo <geir at validalo.net>
wrote:
> The pinout is correct. The right or left is a though question as I don’t
> know what people prefer, however the obd2 can easily be turned on the Soul.
> What about the Fiat, Jason?
> Geir
> Sendt fra min iPhone
> 16. jan. 2018 kl. 05:06 skrev Mark Webb-Johnson <mark at webb-johnson.net>:
> I’ve been dealing with the same custom cable provider since 2012. He’s
> very flexible, fast, and very reliable (especially for OBDII style cables).
> He delivers direct to Fasttech, and we don’t even bother with QC any more -
> he has been 100% perfect for the past five years. All we do is a visual
> inspection and stock count on receipt. MOQ (50) is usually the only issue.
> Pinouts we have in the past produced for OVMS OBDII cables:
> *Pinout A (both left-hand and right-hand right-angled have been produced)*
> J1962-M DB9-F Signal
> 4 3 Chassis/Power GND
> 6 7 CAN-H
> 14 2 CAN-L
> 16 9 +12V Vehicle Power
> J1962 end should be MALE plug with right angle cable. DB9 end should be
> FEMALE.
> Both ends should be enclosed in shells, and cable should be 1metre in
> length.
> *Pinout B (left hand right-angle)*
> 13 7 CAN-H
> 12 2 CAN-L
> J1962 end should be MALE plug with angle cable. DB9 end should be FEMALE.
> length.
> *Pinout C **(both left-hand and right-hand right-angled have been
> produced)*
> 6 7 CAN-H (primary CAN)
> 14 2 CAN-L (primary CAN)
> 13 5 CAN-H (alternate CAN)
> 12 4 CAN-L (alternate CAN)
> length.
> Pinout B was obsoleted in late 2016 and replaced with C. So, currently we
> have A and C variants.
> From my understanding, what you need is:
> *Pinout D*
> 1 5 CAN-H (alternate CAN)
> 9 4 CAN-L (alternate CAN)
> length.
> Would that be in a left or right hand orientation?
> Right: <PastedGraphic-1.tiff>
> On 16 Jan 2018, at 1:39 AM, Geir Øyvind Vælidalo <geir at validalo.net>
> wrote:
> Since we’re closing in on the release date, what should we do regarding
> the cable for the Kia Soul and Fiat 500e? I have yet to find anything
> really useful on the M-bus, but who knows what might come later.
> Jason, how about the Fiat 500e?
> Anyone know the pinouts for Hyundai Ioniq OBD2-port? Maybe it can use the
> same cable too? I couldn’t find the pinouts for that car anywhere…
> Geir
> 13. des. 2017 kl. 01:53 skrev Mark Webb-Johnson <mark at openvehicles.com>:
> Relatively easy. I just give them pinouts, some money, and a week later a
> bunch of cables arrive.
> There is a minimum order quantity of 50 cables from the supplier, so it
> has to be justifiable.
> Perhaps best to have a look at that M-can bus (with a hand-built cable),
> and see if there is anything on it that makes this worthwhile. You can find
> OBDII pigtails on AliExpress/eBay/Amazon that make this relatively simple
> (only need to solder the DB9 end).
> On 13 Dec 2017, at 4:09 AM, Geir Øyvind Vælidalo <geir at validalo.net>
> wrote:
> Hi,
> We might need a special cable for the Kia Soul EV, as it has two CAN-buses
> on the diagnostic port and it doesn’t match the ODB2-cable nor the Nissan
> Leaf-cable.
> Then C-can uses the standard pins 6 and 14, but the M-can uses pins 1
> (high) and 9 (low).
> The M-can should be mapped to CAN1_H (Pin 5 on DB9) and CAN1_L(Pin 4 on
> DB9):
> 1 5 CAN-1H (M-can High)
> 6 7 CAN-0H (C-can high)
> 9 4 CAN-1L (M-can Low)
> 14 2 CAN-0L (C-can low)
> I don’t use the M-can at the moment, and I’m not sure I will, but if I do
> we might need to have a special cable made for the Soul EV.
> Is that something that is easy to fix?
> Geir
Jason Perkins
313 355 0085
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180116/0871ce1e/attachment-0001.html>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180116/0871ce1e/attachment-0001.png>
