[Ovmsdev] Special cable for Kia Soul EV for OVMS V3.
Geir Øyvind Vælidalo
geir at validalo.net
Tue Jan 16 01:39:44 HKT 2018
Since we’re closing in on the release date, what should we do regarding the cable for the Kia Soul and Fiat 500e? I have yet to find anything really useful on the M-bus, but who knows what might come later.
Jason, how about the Fiat 500e?
Anyone know the pinouts for Hyundai Ioniq OBD2-port? Maybe it can use the same cable too? I couldn’t find the pinouts for that car anywhere…
Geir
> 13. des. 2017 kl. 01:53 skrev Mark Webb-Johnson <mark at openvehicles.com>:
> Relatively easy. I just give them pinouts, some money, and a week later a bunch of cables arrive.
> There is a minimum order quantity of 50 cables from the supplier, so it has to be justifiable.
> Perhaps best to have a look at that M-can bus (with a hand-built cable), and see if there is anything on it that makes this worthwhile. You can find OBDII pigtails on AliExpress/eBay/Amazon that make this relatively simple (only need to solder the DB9 end).
>> On 13 Dec 2017, at 4:09 AM, Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net>> wrote:
>> Hi,
>> We might need a special cable for the Kia Soul EV, as it has two CAN-buses on the diagnostic port and it doesn’t match the ODB2-cable nor the Nissan Leaf-cable.
>> Then C-can uses the standard pins 6 and 14, but the M-can uses pins 1 (high) and 9 (low).
>> The M-can should be mapped to CAN1_H (Pin 5 on DB9) and CAN1_L(Pin 4 on DB9):
>> J1962-M DB9-F Signal
>> 1 5 CAN-1H (M-can High)
>> 4 3 Chassis/Power GND
>> 6 7 CAN-0H (C-can high)
>> 9 4 CAN-1L (M-can Low)
>> 14 2 CAN-0L (C-can low)
>> 16 9 +12V Vehicle Power
>> I don’t use the M-can at the moment, and I’m not sure I will, but if I do we might need to have a special cable made for the Soul EV.
>> Is that something that is easy to fix?
>> Geir
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180115/081251d8/attachment.html>
