[Ovmsdev] CAN-3 broken again?
Greg D.
gregd2350 at gmail.com
Sun Jan 14 04:07:28 HKT 2018
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180113/faf53181/attachment-0001.html>
Type: application/octet-stream
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180113/faf53181/attachment-0001.obj>
OVMS > obdii ecu stop
OBDII ECU has been stopped
OVMS > obdii ecu start can3
OBDII ECU has been started
D (5431728) obd2ecu: Added 0x04 resulting 0x10000000
D (5431728) obd2ecu: Added 0x05 resulting 0x18000000
D (5431728) obd2ecu: Added 0x0c resulting 0x18100000
D (5431728) obd2ecu: Added 0x0d resulting 0x18180000
D (5431728) obd2ecu: Added 0x10 resulting 0x18190000
D (5431728) obd2ecu: Added 0x20 resulting 0x18190001
I (5431728) obd2ecu: Metric 'not_a_metric' not found; ignored.
I (5431728) obd2ecu: Using custom metric for pid #4 (0x04)
I (5431728) obd2ecu: Updating custom metric for pid #4 (0x04)
W (5452238) wifi: incorrect scan type: 1073517576
V (5460578) can: RX can3 id 7df len 8: 02 01 00 00 00 00 00 00 | ........
D (5460578) obd2ecu: Rcv 7df: 8 (2 1 0 0 0 0 0 0)
V (5460578) can: TX can3 id 7e8 len 8: 06 41 00 18 19 00 01 55 | .A.....U
V (5460698) can: RX can3 id 7df len 8: 02 01 00 00 00 00 00 00 | ........
D (5460698) obd2ecu: Rcv 7df: 8 (2 1 0 0 0 0 0 0)
V (5460698) can: TX can3 id 7e8 len 8: 06 41 00 18 19 00 01 55 | .A.....U
V (5460818) can: RX can3 id 7df len 8: 02 01 20 00 00 00 00 00 | .. .....
D (5460818) obd2ecu: Rcv 7df: 8 (2 1 20 0 0 0 0 0)
V (5460818) can: TX can3 id 7e8 len 8: 06 41 20 00 00 00 00 55 | .A ....U
V (5460928) can: RX can3 id 7df len 8: 02 09 0a 00 00 00 00 00 | ........
D (5460928) obd2ecu: Rcv 7df: 8 (2 9 a 0 0 0 0 0)
D (5460928) obd2ecu: ECU Name requested
V (5460928) can: TX can3 id 7e8 len 8: 10 17 49 0a 01 53 70 61 | ..I..Spa
V (5460928) can: RX can3 id 7e0 len 8: 30 00 00 00 00 00 00 00 | 0.......
V (5460938) can: TX can3 id 7e8 len 8: 21 63 65 20 66 6f 72 20 | !ce for
V (5460948) can: TX can3 id 7e8 len 8: 22 74 65 78 74 20 68 65 | "text he
V (5460948) can: TX can3 id 7e8 len 8: 23 72 65 00 55 55 55 55 | #re.UUUU
D (5460948) obd2ecu: Rcv 7e0: 8 (30 0 0 0 0 0 0 0)
D (5460948) obd2ecu: flow control frame - ignored
OVMS > can can3 rx standard 7df 02 01 00 00 00 00 00 ff
OVMS > can can3 status
CAN: can3
Mode: Active
Speed: 500000
Rx pkt: 6
Rx err: 0
Rx ovrflw: 0
Tx pkt: 8
Tx delays: 0
Tx err: 0
Tx ovrflw: 0
Err flags: 0
OVMS > can can3 tx standard 7e8 06 41 00 18 19 00 01 ff
CAN: can3
Mode: Active
Speed: 500000
Rx pkt: 6
Rx err: 0
Rx ovrflw: 0
Tx pkt: 9
Tx delays: 0
Tx err: 0
Tx ovrflw: 0
Err flags: 0
V (5469118) can: RX can3 id 7df len 8: 02 01 00 00 00 00 00 ff | ........
D (5469118) obd2ecu: Rcv 7df: 8 (2 1 0 0 0 0 0 ff)
V (5469118) can: TX can3 id 7e8 len 8: 06 41 00 18 19 00 01 55 | .A.....U
V (5469148) can: TX can3 id 7e8 len 8: 06 41 00 18 19 00 01 ff | .A......
