[Ovmsdev] Transition to new esp-idf
Sat Jan 13 05:50:18 HKT 2018
Better sooner than later. Go ahead.
Am 12.01.2018 um 21:44 schrieb Stephen Casner:
> We expect production OVMS to be based on release/v3.1 of esp-idf in
> order to incorporate the support for SPIRAM (PSRAM).
> I'd like to set a target for all develpers to move to the master
> branch of openvehicles/esp-idf that contains the finished version of
> my modifications to support the "module memory" command.  At the same
> time I need to then merge the corresponding changes from my temporary
> branch in openvehicles/Open-Vehicle-Monitoring-System-3 to the master
> branch there since the API between the two has changed.
> In other words, we need a flag day.
