[Ovmsdev] CAN-3 broken again?
Mon Jan 8 08:07:04 HKT 2018
> Mark:� Note also the issue with DNS failures getting to the v2 server.� I enabled the modem, got connected, then enabled WiFi (simulating arriving at home), and lost the V2 server.� Disabling Wifi didn't bring it back, and powering off the modem (in preparation for turning it back on) caused the crash.
Yep, I’m aware of that. Discussed on the list a few days ago - seems to be the DNS server configuration when both WiFi and PPP running at the same time.
> Second, overall memory usage seems to be at the limit.� What sort of budget do we have for what remains to be done, and how are we going to be packaging the build options for when non-developers want to get their hands on the product?� Will we be able to turn everything on, minus the developer / debug stuff, or will we have a separate SKU for each model car?
The OTA system supports both. I’d prefer everything in one build, but it really depends on the flash footprint we end up with.
> On 8 Jan 2018, at 3:05 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi Michael, Steve, Mark,
> Steve, the crash was an abort in new_op.cc, so perhaps being out of space is the issue.� Crash and reboot log attached (crash.txt).� One thing I've been wondering about are the several lines "_WindowOverflow4 at ??:?" during the boot process.� Is that indicative of a problem, later to manifest in the crash?
> My builds include pretty much everything, except for the Leaf, Twizy, and Soul.�
> The update included some 20 lines changed to mcp2525.cpp, as well as a bunch of other stuff, including a lot stuff updated in Canopen and Kia.� I have a script that does the git fetch master, merge, and push back to my github fork, the output of which is attached (update.txt).� As a test, I removed Canopen from the build config, and the crash has disappeared.� CAN-3 also appears to have come back to life (!), at least initially.� I can still get CAN-3 to fail if I turn on/off the modem and/or wifi in some sequence (still trying to pin that down), but that also leads to another crash (crash2.txt, attached).�
> So, two questions...� First, why the apparent conflict between Canopen or wifi/modem and obd2ecu over access to the 3rd CAN bus?� Why would the modem or wifi have any effect on a CAN bus?
> Thanks,
> Greg
> Michael Balzer wrote:
>> Greg,
>> which commits / changes do you mean? The CAN drivers have not been changed since the TX performance fix, which Geir reported having solved his last issues.
>> The current version is stable over here, but without the SSH component -- I can't use that due to memory getting too low together with the Twizy component.
>> Am 07.01.2018 um 08:04 schrieb Greg D.:
>>> Hi folks,
>>> I just resync'd with the main repository, and am not receiving frames on
>>> CAN-3 anymore. I see there were changes to the chip driver...
>>> I'm also seeing crashes right after getting connected to WiFi,
>>> immediately after the system tries to start SSH.
>>> Seems like we just took a big step backward. What happened?
>>> Greg
> <update.txt><crash.txt><crash2.txt>_______________________________________________
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180108/be536d89/attachment.html>
