[Ovmsdev] CAN-3 broken again?
Sun Jan 7 18:29:24 HKT 2018
Greg,
which commits / changes do you mean? The CAN drivers have not been changed since the TX performance fix, which Geir reported having solved his last issues.
The current version is stable over here, but without the SSH component -- I can't use that due to memory getting too low together with the Twizy component.
Am 07.01.2018 um 08:04 schrieb Greg D.:
> Hi folks,
> I just resync'd with the main repository, and am not receiving frames on
> CAN-3 anymore.  I see there were changes to the chip driver...
> I'm also seeing crashes right after getting connected to WiFi,
> immediately after the system tries to start SSH.
> Seems like we just took a big step backward.  What happened?
> Greg
