[Ovmsdev] Modem link-drop crash^H^H^H^H^H Stuck
Mon Jan 1 02:49:09 HKT 2018
Mark Webb-Johnson wrote:
> I’ve been rock solid for three days here, and a couple of network reconnects in that time.
> But my tcp/is stack size is 4096bytes. Can you check yours in menuconfig, component config, LWIP, tcp/ip task stack size? My tiT task grows to 2472/4096 bytes.
> Regards, Mark
I let yesterday's code run on the bench last night.  Awoke to it being
stuck...  Here's the transition zone.  Thoughts?
I (9715181) ovms-server-v2: Send MP-0
S0,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
I (9715191) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,9712,0,0,0,0,0,0,0,0,0,0
I (10316191) ovms-server-v2: Send MP-0
I (10316201) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,10313,0,0,0,0,0,0,0,0,0,0
I (10917201) ovms-server-v2: Send MP-0
I (10917211) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,10914,0,0,0,0,0,0,0,0,0,0
I (11518211) ovms-server-v2: Send MP-0
I (11518221) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,11515,0,0,0,0,0,0,0,0,0,0
I (12119221) ovms-server-v2: Send MP-0
I (12119231) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,12116,0,0,0,0,0,0,0,0,0,0
I (12720231) ovms-server-v2: Send MP-0
I (12720241) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,12717,0,0,0,0,0,0,0,0,0,0
I (13321241) ovms-server-v2: Send MP-0
I (13321251) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,13318,0,0,0,0,0,0,0,0,0,0
I (13922251) ovms-server-v2: Send MP-0
I (13922261) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,13919,0,0,0,0,0,0,0,0,0,0
I (14523261) ovms-server-v2: Send MP-0
I (14523271) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,14520,0,0,0,0,0,0,0,0,0,0
I (15124271) ovms-server-v2: Send MP-0
I (15124281) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,15121,0,0,0,0,0,0,0,0,0,0
I (15725281) ovms-server-v2: Send MP-0
I (15725291) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,15722,0,0,0,0,0,0,0,0,0,0
I (16326291) ovms-server-v2: Send MP-0
I (16326301) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,16323,0,0,0,0,0,0,0,0,0,0
I (16927301) ovms-server-v2: Send MP-0
I (16927311) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,16924,0,0,0,0,0,0,0,0,0,0
I (17528311) ovms-server-v2: Send MP-0
I (17528321) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,17525,0,0,0,0,0,0,0,0,0,0
I (18129321) ovms-server-v2: Send MP-0
I (18129331) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,18126,0,0,0,0,0,0,0,0,0,0
I (18730331) ovms-server-v2: Send MP-0
I (18730341) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,18727,0,0,0,0,0,0,0,0,0,0
I (19331341) ovms-server-v2: Send MP-0
I (19331351) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,19328,0,0,0,0,0,0,0,0,0,0
I (19932351) ovms-server-v2: Send MP-0
I (19932361) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,19929,0,0,0,0,0,0,0,0,0,0
I (20029401) simcom: CREG Network Registration: Searching
I (20029461) simcom: Lost network connection (NetworkRegistration in
NetMode)
I (20029461) simcom: State: Enter NetLoss state
I (20029461) gsm-ppp: Shutting down (hard)...
I (20029461) ovms-server-v2: Network is down, so disconnect network
connection
E (20029461) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (20029471) gsm-ppp: StatusCallBack: User Interrupt
I (20029471) gsm-ppp: PPP connection has been closed
I (20038461) simcom: State timeout, transition to 5
I (20038461) simcom: State: Enter NetWait state
I (20039461) ovms-server-v2: Status: Waiting for network connectivity
I (20048481) simcom: CREG Network Registration: RegisteredRoaming
I (20049461) simcom: State: Enter NetStart state
I (20050551) simcom: PPP Connection is ready to start
I (20051461) simcom: State: Enter NetMode state
I (20051461) gsm-ppp: Initialising...
I (20054951) gsm-ppp: StatusCallBack: None
I (20054951) gsm-ppp: status_cb: Connected
I (20054951) gsm-ppp:    our_ipaddr  = 10.170.146.142
I (20054951) gsm-ppp:    his_ipaddr  = 10.64.64.64
I (20054951) gsm-ppp:    netmask     = 255.255.255.255
I (20054951) gsm-ppp:    our6_ipaddr = ::
I (20059461) ovms-server-v2: Status: Network connectivity established
I (20059461) ovms-server-v2: Connection is tmc.openvehicles.com:6867
ROADSTER_834/Gdbkt2017server
I (20061011) ovms-server-v2: Connected to OVMS Server V2 at
I (20061021) ovms-server-v2: Status: Connected to server
I (20061021) ovms-server-v2: Status: Logging in...
I (20061021) ovms-server-v2: Sending server login: MP-C 0
NYaGgvcdnGlWDJSTSLKl7H 5S2UgEGKxSfoz5fRc+LYJw== ROADSTER_834
I (20061991) ovms-server-v2: Received welcome response MP-S 0
igcHhkZQpibm/UgepO3KdO 8wI19Wfa/W/6uzgSkRzNKA==
I (20061991) ovms-server-v2: Got server response: MP-S 0
I (20061991) ovms-server-v2: Server token is igcHhkZQpibm/UgepO3KdO and
digest is 8wI19Wfa/W/6uzgSkRzNKA==
I (20061991) ovms-server-v2: Status: Server auth ok. Now priming crypto.
I (20061991) ovms-server-v2: Shared secret key is
igcHhkZQpibm/UgepO3KdONYaGgvcdnGlWDJSTSLKl7H (44 bytes)
I (20062001) ovms-server-v2: Status: OVMS V2 login successful, and
crypto channel established
I (20062001) ovms-server-v2: Status: Connected and logged in
I (20062011) ovms-server-v2: Incoming Msg: MP-0 Z0
I (20533011) ovms-server-v2: Send MP-0
I (20533021) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,20530,0,0,0,0,0,0,0,0,0,0
I (20533021) ovms-server-v2: Send MP-0 F3.0.0/factory/main build (idf
v2.1-75-g72bb091a) Dec 30 2017
21:39:01,123456789abcdefgh,8,1,TR,T-Mobile Hologram
I (21134041) ovms-server-v2: Send MP-0
I (21134051) ovms-server-v2: Send MP-0
D0,0,5,0,0,0,0,0,0,21131,0,0,0,0,0,0,0,0,0,0
E (21155011) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
I (21155011) simcom: PPP Connection disconnected
I (21155461) simcom: Lost network connection (+PPP disconnect in NetMode)
I (21155461) simcom: State: Enter NetLoss state
I (21155461) gsm-ppp: Shutting down (hard)...
I (21155461) ovms-server-v2: Network is down, so disconnect network
connection
I (21160991) gsm-ppp: StatusCallBack: User Interrupt
I (21160991) gsm-ppp: PPP connection has been closed
I (21164461) simcom: State timeout, transition to 5
I (21164461) simcom: State: Enter NetWait state
I (21165021) ovms-server-v2: Status: Waiting for network connectivity
I (21168461) simcom: State: Enter NetStart state
I (21169551) simcom: PPP Connection is ready to start
I (21170461) simcom: State: Enter NetMode state
I (21170461) gsm-ppp: Initialising...
I (21170651) simcom: PPP Connection disconnected
I (21171461) simcom: Lost network connection (+PPP disconnect in NetMode)
I (21171461) simcom: State: Enter NetLoss state
I (21171461) gsm-ppp: Shutting down (hard)...
I (21180461) simcom: State timeout, transition to 5
I (21180461) simcom: State: Enter NetWait state
I (21183451) gsm-ppp: StatusCallBack: User Interrupt
I (21183451) gsm-ppp: PPP connection has been closed
I (21184461) simcom: State: Enter NetStart state
I (21185551) simcom: PPP Connection is ready to start
I (21186461) simcom: State: Enter NetMode state
I (21186461) gsm-ppp: Initialising...
I (21186631) simcom: PPP Connection disconnected
I (21187461) simcom: Lost network connection (+PPP disconnect in NetMode)
I (21187461) simcom: State: Enter NetLoss state
I (21187461) gsm-ppp: Shutting down (hard)...
I (21196461) simcom: State timeout, transition to 5
I (21196461) simcom: State: Enter NetWait state
I (21199451) gsm-ppp: StatusCallBack: User Interrupt
I (21199451) gsm-ppp: PPP connection has been closed
I (21200461) simcom: State: Enter NetStart state
I (21201531) simcom: PPP Connection is ready to start
I (21202461) simcom: State: Enter NetMode state
I (21202461) gsm-ppp: Initialising...
I (21202641) simcom: PPP Connection disconnected
I (21203461) simcom: Lost network connection (+PPP disconnect in NetMode)
I (21203461) simcom: State: Enter NetLoss state
I (21203461) gsm-ppp: Shutting down (hard)...
I (21212461) simcom: State timeout, transition to 5
I (21212461) simcom: State: Enter NetWait state
I (21215451) gsm-ppp: StatusCallBack: User Interrupt
I (21215451) gsm-ppp: PPP connection has been closed
I (21216461) simcom: State: Enter NetStart state
I (21217541) simcom: PPP Connection is ready to start
I (21218461) simcom: State: Enter NetMode state
I (21218461) gsm-ppp: Initialising...
I (21218571) simcom: PPP Connection disconnected
I (21219461) simcom: Lost network connection (+PPP disconnect in NetMode)
