[Ovmsdev] Crash / reboot loop with log level Info
    Stephen Casner
    casner at acm.org
    Tue Feb 27 05:45:52 HKT 2018
Merged.
On Mon, 26 Feb 2018, Greg D. wrote:
> Excellent.  Change pushed to my fork; pull request created.
> Thanks!
> Greg
> Michael Balzer wrote:
> > I second that, the normal stack usage for the Housekeeper is already quite close to 4K:
> > Number of Tasks = 19       Stack:  Now   Max Total    Heap 32-bit SPIRAM
> > Task 3FFD3718 14 Housekeeping      356  3396  4096   91940      0      0
> > So I also think 6K should be the default.
> > Regards,
> > Michael
> > Am 26.02.2018 um 08:54 schrieb Stephen Casner:
> >> Greg,
> >> Presuming that you are not doing some activity in the Housekeeping
> >> task that should really be done in some other task, and presuming that
> >> the activity you are doing is not something unreasonable, then indeed
> >> you have found a valid need for a larger stack and the change should
> >> be committed.  The value 6144 is a reasonable step up.
> >>                                                         -- Steve
> >> On Sun, 25 Feb 2018, Greg D. wrote:
> >>> Ha, yes.  Sorry.  I bumped it up to 6144 (seems like a popular value),
> >>> and that fixed it.
> >>> So, two questions:
> >>> 1.  What should a proper value be?  I used 6144 only because I'd seen it
> >>> used elsewhere.
> >>> 2.  Shall I push this for permanence?
> >>> Thanks,
> >>> Greg
