[Ovmsdev] Crash / reboot loop with log level Info
    Stephen Casner
    casner at acm.org
    Mon Feb 26 08:40:31 HKT 2018
Greg,
It sounds to me like you are conflating stack overflow with running
out of heap space.  You are not having a problem (yet) of running out
of heap space, you have a stack size that is configured too small for
your program's requirements.  From what I saw in your earlier message,
you need to change the creation of the Housekeeping task to specify a
larger stack.
On Sun, 25 Feb 2018, Greg D. wrote:
> Hi Steve,
> I don't see any evidence that there is a recursive loop here, just the
> buffers stacking up, causing the overflow.  Odd, though, this used to
> work.  Not sure what else changed at that time besides the logging
> level; if I recall, it was part of a larger update.
> But given that we have a RAM fix coming, is it worth messing with this?
> Greg
> Stephen Casner wrote:
> > Greg,
> > Unless there is a bug causing infinite recursion or something, you may
> > have sufficient free RAM to allow increasing the size of the stack for
> > the task that is getting the stack overflow and achieve successful
> > operation.
> >                                                         -- Steve
> > OvmsDev mailing list
> > OvmsDev at lists.teslaclub.hk
