[Ovmsdev] Moving to a production cycle
    Sun Feb 25 20:04:11 HKT 2018
Am 25.02.2018 um 01:12 schrieb Stephen Casner:
> In order for a module that has been configured to become useful
> automatically after power cycles it will be necessary for the start-up
> script(s) to execute commands that require being enabled.  If that
> requires putting an enable command with clear-text password into the
> startup script, that's not good.
Good point.
How about allowing write access to event scripts on "/store" only in enabled mode and then generally run those scripts in enabled mode?
