[Ovmsdev] Moving to a production cycle
    Wed Feb 21 10:05:08 HKT 2018
My v3.1 test board seems stable, and we are ready for hardware production. I’m ordering the components with relatively long lead times (weeks) now, and the production order will go in as soon as China comes back from holiday (next week). First hardware batch will be available during March. I know lots of people are waiting for this, but I have to balance that against risk (should some hardware issue be found during wider real-world testing). I currently plan to order 120 modules (including 60 USA 3G modems, and 60 EU 3G modems) for the first batch. 100 will go to FastTech (for general ordering), and 20 to me (for special cases). As with OVMS v1, we’ll clearly say these are early units for ‘technically capable’ people, and the firmware still has a way to go.
On the firmware side, we need to move to a production style release cycle, and I will need to provide the first ‘factory’ firmware around the second week of March. Accordingly, I’m setting up some clean build environments and OTA release repositories (so I can cleanly build v3.0 and v3.1 firmware and have it available for OTA download).
I have created a changes.txt log file in the root of the project. I would appreciate it if those with commit access to master could update that file when they merge/commit changes to the project. The top of the file will contain an entry for the ‘next’ version, so the change text just needs to be added below that. When the version is ready to go, I will update changes.txt with the date and name, commit it, tag it, and then build OTA versions for release. Please only use tags for OTA versions - or just don’t tag at all for the moment and let me maintain this.
The last list of things I have for this build are:
OTA via HTTP. SD CARD firmware updates seems to work fine today, as does serial flashing. I’ve still got to make the changes to HTTP firmware updates to use mongoose and support the new ESP IDF v2.1+ firmware arrangement of putting the checksum at the end of the firmware file.
We need some simple high-level configs for auto-starting things. Stuff like vehicle type, whether the v2 server should auto-run, etc. Make it simpler for people to configure, without having to use scripts. This can be mapped to v2 protocol parameters/features.
SPI RAM support and stability for v3.1 hardware (as well as compatibility with v3.0 hardware).
Finalise the partition sizes. I think we can squeeze a bit more (maybe 3x 5MB firmwares, plus 512KB store?).
End-User Documentation.
Real-world stability (in cars).
My concern is to have a relatively stable firmware that is usable for technically capable end-users in their cars, but also to have a way for them to simply update the firmware to keep pace with the fast release cycle we expect (at least in the coming months).
Anything I’ve missed?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180221/b2a311e5/attachment.htm>
