[Ovmsdev] /store gone
    Greg D.
    gregd2350 at gmail.com
    Sat Feb 17 10:56:08 HKT 2018
Ah, ok then.  I did a vfs ls of it, and nothing got returned, so tried
catting it.
If it's a directory, what should I normally find in there?  I have not
tried to set any config parameters as yet.  Is it worth trying to do so
(writing to flash)?
Greg
Mark Webb-Johnson wrote:
> Ovms_config is a directory. Don’t think you can cat it.
> Regards, Mark
>> On 17 Feb 2018, at 10:32 AM, Greg D. <gregd2350 at gmail.com> wrote:
>> Hi Steve,
>> No, it's just "cannot be opened:"
>> OVMS > vfs ls /store
>> <snip 124 lines>
>> ovms_config
>> OVMS > vfs cat /store/ovms_config
>> Error: VFS file cannot be opened
>> OVMS > vfs stat /store/ovms_config
>> OVMS >
>> I just noticed that there are 128 lines of bogus files (power of 2 a
>> coincidence?), prior to ovms_config.
>> Greg
>> Stephen Casner wrote:
>>> Greg,
>>>> But, if I try to vfs cat the file, ovms complains that the file
>>>> cannot be opened.
>>> Just checking... Is the complaint "Error: protected path"?  If so, you
>>> have to set:
>>> CONFIG_OVMS_DEV_CONFIGVFS=y
>>> in sdkconfig to allow access with the vfs commands.
>>>                                                        -- Steve
