[Ovmsdev] /store gone (was: Re: Awfully quiet out there)
Sat Feb 17 07:26:59 HKT 2018
The string is built using git describe, which fetches the most recent tag from the current tree:
balzer at leela:~/esp/esp-idf> git describe --always --tags --dirty
v3.1-dev-391-g8d8d62da
That's set at…
balzer at leela:~/esp/esp-idf> git show v3.1-dev
commit 22489d70214a5b7650ab197ffd6ab73e9c50a772
Merge: c4448714 f58c5b21
Author: Jiang Jiang Jian <jack at espressif.com>
Date:   Fri Dec 1 22:06:43 2017 +0800
    Merge branch 'bugfix/wdt_periph_enable' into 'master'
    watchdogs: make sure timer group peripherals are enabled
    See merge request !1623
So you're missing that tag ref after doing a fresh clone…
…and indeed, the tag is missing from our fork on github, it's only present in the esp origin:
https://github.com/openvehicles/esp-idf/tree/v3.1-dev → 404
https://github.com/espressif/esp-idf/tree/v3.1-dev → ok
So it seems we forgot to push the tags we fetched from upstream into our own fork. I did that now, so if you pull again, you should get the tag and the version
string should be up to date.
But that should have had no effect on your issue then, as the revision tree is consistent. Tags are just that -- tags.
Another idea on your issue then: is your partition table unchanged & correct?
balzer at leela:~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3> cat partitions.csv
# OVMS 16MB flash ESP32 Partition Table
# Name,   Type, SubType, Offset,   Size
nvs,      data, nvs,     0x9000,  0x4000
otadata,  data, ota,     0xd000,  0x2000
phy_init, data, phy,     0xf000,  0x1000
factory,  app,  factory, 0x10000,  4M
ota_0,    app,  ota_0,   ,         4M
ota_1,    app,  ota_1,   ,         4M
store,    data, fat,     ,         1M
Am 16.02.2018 um 19:24 schrieb Greg D.:
> Hi Michael,
> Yes, that was one of the first things I checked.  It points to /home/greg/esp/esp-idf, which is the current esp-idf directory.
> m.version is this:
> OVMS > metrics list m.version
> m.version                                3.0.0/factory/main build (idf v3.0-dev-1781-g8d8d62da) Feb 15 2018 22:01:48
> OVMS >
> Where would I find the source of that string in the build environment?
> Greg
> Michael Balzer wrote:
>> Greg,
>> have you checked your IDF_PATH?
>> What does "m.version" show?
>> Am 16.02.2018 um 09:27 schrieb Greg D.:
>>> Present and accounted for.  Also, when I compile code, there's no warning about cross-versions, and I have a fresh copy of esp-idf from Github.  When I had
>>> the wrong branch, there was a warning about mismatched versions.
>>> So, the git log matches, yet what I'm building doesn't; that's like, impossible, right?
>>> Greg
>>> Mark Webb-Johnson wrote:
>>>> Another thought - maybe the compiler version?
>>>> 3.1 requires xtensa gcc 1.22.0-80 (g6c4433a-5.2.0).
>>>>     https://esp-idf.readthedocs.io/en/latest/get-started/linux-setup.html
>>>> Regards, Mark.
>>>>> On 16 Feb 2018, at 2:19 PM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>>>> Mine says:
>>>>> m.version
>>>>> 3.0.0/factory/main build (idf v3.1-dev-212-g00fa3889-dirty) Feb  7 2018 22:10:10
>>>>> But, truth be told, I'm currently compiing from my own fork of
>>>>> espressif/esp-idf that I set up to issue a PR to espressif for my
>>>>> changes that support the memory diagnostics.
>>>>>                                                        -- Steve
>>>>> On Thu, 15 Feb 2018, Greg D. wrote:
>>>>>> Ok.  Back to half-sanity.  rm -rf esp-idf, Refetched from master including submodule
>>>>>> stuff, rm -r build, make clean, make, make flash.  Compiles and runs.
>>>>>> But still shows wrong version for m.version, and /store is still a mess.  Not sure if
>>>>>> I care about the m.version; what is going on with vfs?
>>>>>> Back to the TV...
>>>>>> Greg
>>>>>> Stephen Casner wrote:
>>>>>> Right.
>>>>>>     -- Steve
>>>>>> Ok, so master from the openvehicles clone?
>>>>>> Greg
>>>>>> Gre,
>>>>>> No, we left behind the v2.1 of esp-idf a while ago.  We're now on
>>>>>> master.
>>>>>>                                                        -- Steve
>>>>>> Mmm, never mind...  I realize we're still based on v2.1, right?
>>>>>> I've re-fetched stuff from the 2.1 branch, and still have the same results.  v3.0.0
>>>>>> listed as m.version, and junk in /store.
>>>>>> Now what?
>>>>>> Greg
>>>>>> Greg D. wrote:
>>>>>>      Ok, this is odd...  Are you sure esp-idf v3.1 is actually on Github?
>>>>>>      Tried re-fetching everything, and found this:
>>>>>>            greg at linux-0rpb:~/esp> git clone
>>>>>>            https://github.com/openvehicles/esp-idf.git
>>>>>>            Cloning into 'esp-idf'...
>>>>>>            remote: Counting objects: 44182, done.
>>>>>>            remote: Compressing objects: 100% (8/8), done.
>>>>>>            remote: Total 44182 (delta 0), reused 1 (delta 0), pack-reused
>>>>>>            44174
>>>>>>            Receiving objects: 100% (44182/44182), 50.53 MiB | 11.75
>>>>>>            MiB/s, done.
>>>>>>            Resolving deltas: 100% (31074/31074), done.
>>>>>>            greg at linux-0rpb:~/esp> cd esp-idf
>>>>>>            greg at linux-0rpb:~/esp/esp-idf> git branch -a
>>>>>>            * master
>>>>>>              remotes/origin/HEAD -> origin/master
>>>>>>              remotes/origin/feature/psram_malloc
>>>>>>              remotes/origin/master
>>>>>>              remotes/origin/release/v2.0
>>>>>>              remotes/origin/release/v2.1
>>>>>>              remotes/origin/release/v3.0
>>>>>>      Shouldn't there be a v3.1 listed there too?  Last entry is 3.0.
>>>>>>      Anyway, the first question is whether we have one problem or two...  Is my
>>>>>>      problem with /store related to v3.0 vs v3.1, or is it a separate problem
>>>>>>      on its own?  Do I simply need to clear flash and reload my config?  If so,
>>>>>>      what is the best way?
>>>>>>      Greg
>>>>>>      Nope. Old hardware.
>>>>>> Out of ideas. I thought it just picked up the git version.
>>>>>> Regards, Mark.
>>>>>>      On 15 Feb 2018, at 12:07 PM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>>
>>>>>>      wrote:
>>>>>> No difference.
>>>>>> Are you on the new hardware?
>>>>>> Greg
>>>>>>      In your ovms directory:
>>>>>>      make clean
>>>>>> rm -rf build
>>>>>> make flash
>>>>>> That’s all I can think of.
>>>>>> Regards, Mark
>>>>>>      On 15 Feb 2018, at 11:59 AM, Greg D.
>>>>>>      <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>>>> Yes, and yes.  The top entry exactly matches your log.
>>>>>> Greg
>>>>>>      And you’ve already ‘git pull’ and ‘git
>>>>>>      submodule update’ in that esp idf?
>>>>>> If you ‘git log’, you should get:
>>>>>>      commit
>>>>>>      8d8d62da9e58305c8f7f4792264f8cab3ffe104b
>>>>>>      (HEAD -> master, origin/master,
>>>>>>      origin/HEAD)
>>>>>> Merge: 5bf85d06 ca3faa61
>>>>>> Author: Mark Webb-Johnson
>>>>>> <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>>>>>> Date:   Tue Feb 13 13:27:55 2018 +0800
>>>>>>     Merge remote-tracking branch
>>>>>> 'espressif/master'
>>>>>> (which is where the 8d8d62da comes from)
>>>>>> Regards, Mark.
>>>>>>      On 15 Feb 2018, at 11:42 AM, Greg D.
>>>>>> Yes and yes.
>>>>>>      git branch -a
>>>>>>      * master
>>>>>>      origin/master
>>>>>>      git remote -v
>>>>>>      origin
>>>>>>      (fetch)
>>>>>>      origin
>>>>>>      (push)
>>>>>> Greg
>>>>>>      In your esp idf directory, can
>>>>>>      you check ‘git branch -a’. Make
>>>>>>      sure you are on ‘master’ branch.
>>>>>>      Also ‘git remote -v’. Make sure
>>>>>>      you are on openvehicles clone.
>>>>>> Mark
>>>>>>      On 15 Feb 2018, at 10:24
>>>>>>      AM, Greg D.
>>>>>>      wrote:
>>>>>> Hi Mark,
>>>>>> So, I changed the
>>>>>> CONFIG_LWIP_SO_REUSE value and
>>>>>> did a make flash.  That
>>>>>> displayed another option,
>>>>>> default Yes, changed to no.
>>>>>> But, same result with /store.
>>>>>> One significant difference is
>>>>>> that you're on idf 3.1 and I'm
>>>>>> on 3.0...  (3.0.0/factory/main
>>>>>> build (idf
>>>>>> v3.0-dev-1781-g8d8d62da) Feb 14
>>>>>> 2018 18:12:05)
>>>>>> Did I miss a cog on this?
>>>>>> Greg
>>>>>>      My store seems ok:
>>>>>>      OVMS > vfs ls
>>>>>>      /store
>>>>>> ovms_config
>>>>>> obd2ecu
>>>>>> play
>>>>>> OVMS > metrics list
>>>>>> m.version
>>>>>> m.version
>>>>>>  3.0.0/factory/main
>>>>>> build (idf
>>>>>> v3.1-dev-391-g8d8d62da)
>>>>>> Feb 13 2018 14:05:21
>>>>>> Anybody else seeing this
>>>>>> issue?
>>>>>> Regarding the
>>>>>> CONFIG_LWIP_SO_REUSE, in
>>>>>> menuconfig you can use ‘/‘
>>>>>> to search for it. The
>>>>>> parameter is in Component
>>>>>> Config / LWIP.
>>>>>> Regards, Mark.
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180217/c1325f54/attachment.htm>
