[Ovmsdev] Awfully quiet out there
    Fri Feb 16 17:29:37 HKT 2018
Greg,
have you checked your IDF_PATH?
What does "m.version" show?
Am 16.02.2018 um 09:27 schrieb Greg D.:
> Present and accounted for.  Also, when I compile code, there's no warning about cross-versions, and I have a fresh copy of esp-idf from Github.  When I had
> the wrong branch, there was a warning about mismatched versions.
> So, the git log matches, yet what I'm building doesn't; that's like, impossible, right?
> Greg
> Mark Webb-Johnson wrote:
>> Another thought - maybe the compiler version?
>> 3.1 requires xtensa gcc 1.22.0-80 (g6c4433a-5.2.0).
>>     https://esp-idf.readthedocs.io/en/latest/get-started/linux-setup.html
>>> On 16 Feb 2018, at 2:19 PM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>> Mine says:
>>> OVMS > metrics list m.version
>>> m.version
>>> 3.0.0/factory/main build (idf v3.1-dev-212-g00fa3889-dirty) Feb  7 2018 22:10:10
>>> But, truth be told, I'm currently compiing from my own fork of
>>> espressif/esp-idf that I set up to issue a PR to espressif for my
>>> changes that support the memory diagnostics.
>>>                                                        -- Steve
>>> On Thu, 15 Feb 2018, Greg D. wrote:
>>>> Ok.  Back to half-sanity.  rm -rf esp-idf, Refetched from master including submodule
>>>> stuff, rm -r build, make clean, make, make flash.  Compiles and runs.
>>>> But still shows wrong version for m.version, and /store is still a mess.  Not sure if
>>>> I care about the m.version; what is going on with vfs?
>>>> Back to the TV...
>>>> Greg
>>>> Stephen Casner wrote:
>>>> Right.
>>>>     -- Steve
>>>> Ok, so master from the openvehicles clone?
>>>> Greg
>>>> Gre,
>>>> No, we left behind the v2.1 of esp-idf a while ago.  We're now on
>>>> master.
>>>>                                                        -- Steve
>>>> Mmm, never mind...  I realize we're still based on v2.1, right?
>>>> I've re-fetched stuff from the 2.1 branch, and still have the same results.  v3.0.0
>>>> listed as m.version, and junk in /store.
>>>> Now what?
>>>> Greg
>>>> Greg D. wrote:
>>>>      Ok, this is odd...  Are you sure esp-idf v3.1 is actually on Github?
>>>>      Tried re-fetching everything, and found this:
>>>>            greg at linux-0rpb:~/esp> git clone
>>>>            https://github.com/openvehicles/esp-idf.git
>>>>            Cloning into 'esp-idf'...
>>>>            remote: Counting objects: 44182, done.
>>>>            remote: Compressing objects: 100% (8/8), done.
>>>>            remote: Total 44182 (delta 0), reused 1 (delta 0), pack-reused
>>>>            44174
>>>>            Receiving objects: 100% (44182/44182), 50.53 MiB | 11.75
>>>>            MiB/s, done.
>>>>            Resolving deltas: 100% (31074/31074), done.
>>>>            greg at linux-0rpb:~/esp> cd esp-idf
>>>>            greg at linux-0rpb:~/esp/esp-idf> git branch -a
>>>>            * master
>>>>              remotes/origin/HEAD -> origin/master
>>>>              remotes/origin/feature/psram_malloc
>>>>              remotes/origin/master
>>>>              remotes/origin/release/v2.0
>>>>              remotes/origin/release/v2.1
>>>>              remotes/origin/release/v3.0
>>>>      Shouldn't there be a v3.1 listed there too?  Last entry is 3.0.
>>>>      Anyway, the first question is whether we have one problem or two...  Is my
>>>>      problem with /store related to v3.0 vs v3.1, or is it a separate problem
>>>>      on its own?  Do I simply need to clear flash and reload my config?  If so,
>>>>      what is the best way?
>>>>      Greg
>>>>      Nope. Old hardware.
>>>> Out of ideas. I thought it just picked up the git version.
>>>> Regards, Mark.
>>>>      On 15 Feb 2018, at 12:07 PM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>>
>>>>      wrote:
>>>> No difference.
>>>> Are you on the new hardware?
>>>> Greg
>>>>      In your ovms directory:
>>>>      make clean
>>>> rm -rf build
>>>> make flash
>>>> That’s all I can think of.
>>>> Regards, Mark
>>>>      On 15 Feb 2018, at 11:59 AM, Greg D.
>>>>      <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>> Yes, and yes.  The top entry exactly matches your log.
>>>> Greg
>>>>      And you’ve already ‘git pull’ and ‘git
>>>>      submodule update’ in that esp idf?
>>>> If you ‘git log’, you should get:
>>>>      commit
>>>>      8d8d62da9e58305c8f7f4792264f8cab3ffe104b
>>>>      (HEAD -> master, origin/master,
>>>>      origin/HEAD)
>>>> Merge: 5bf85d06 ca3faa61
>>>> Author: Mark Webb-Johnson
>>>> <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>>>> Date:   Tue Feb 13 13:27:55 2018 +0800
>>>>     Merge remote-tracking branch
>>>> 'espressif/master'
>>>> (which is where the 8d8d62da comes from)
>>>> Regards, Mark.
>>>>      On 15 Feb 2018, at 11:42 AM, Greg D.
>>>> Yes and yes.
>>>>      git branch -a
>>>>      * master
>>>>      origin/master
>>>>      git remote -v
>>>>      origin
>>>>      (fetch)
>>>>      origin
>>>>      (push)
>>>> Greg
>>>>      In your esp idf directory, can
>>>>      you check ‘git branch -a’. Make
>>>>      sure you are on ‘master’ branch.
>>>>      Also ‘git remote -v’. Make sure
>>>>      you are on openvehicles clone.
>>>> Mark
>>>>      On 15 Feb 2018, at 10:24
>>>>      AM, Greg D.
>>>>      wrote:
>>>> Hi Mark,
>>>> So, I changed the
>>>> CONFIG_LWIP_SO_REUSE value and
>>>> did a make flash.  That
>>>> displayed another option,
>>>> default Yes, changed to no.
>>>> But, same result with /store.
>>>> One significant difference is
>>>> that you're on idf 3.1 and I'm
>>>> on 3.0...  (3.0.0/factory/main
>>>> build (idf
>>>> v3.0-dev-1781-g8d8d62da) Feb 14
>>>> 2018 18:12:05)
>>>> Did I miss a cog on this?
>>>> Greg
>>>>      My store seems ok:
>>>>      OVMS > vfs ls
>>>>      /store
>>>> ovms_config
>>>> obd2ecu
>>>> play
>>>> OVMS > metrics list
>>>> m.version
>>>> m.version
>>>>  3.0.0/factory/main
>>>> build (idf
>>>> v3.1-dev-391-g8d8d62da)
>>>> Feb 13 2018 14:05:21
>>>> Anybody else seeing this
>>>> issue?
>>>> Regarding the
>>>> CONFIG_LWIP_SO_REUSE, in
>>>> menuconfig you can use ‘/‘
>>>> to search for it. The
>>>> parameter is in Component
>>>> Config / LWIP.
>>>> Regards, Mark.
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180216/4bb04715/attachment.htm>
