[Ovmsdev] Awfully quiet out there
    Fri Feb 16 16:06:48 HKT 2018
Another thought - maybe the compiler version?
3.1 requires xtensa gcc 1.22.0-80 (g6c4433a-5.2.0).
https://esp-idf.readthedocs.io/en/latest/get-started/linux-setup.html <https://esp-idf.readthedocs.io/en/latest/get-started/linux-setup.html>
> On 16 Feb 2018, at 2:19 PM, Stephen Casner <casner at acm.org> wrote:
> Mine says:
> OVMS > metrics list m.version
> m.version
> 3.0.0/factory/main build (idf v3.1-dev-212-g00fa3889-dirty) Feb  7 2018 22:10:10
> But, truth be told, I'm currently compiing from my own fork of
> espressif/esp-idf that I set up to issue a PR to espressif for my
> changes that support the memory diagnostics.
> On Thu, 15 Feb 2018, Greg D. wrote:
>> Ok.  Back to half-sanity.  rm -rf esp-idf, Refetched from master including submodule
>> stuff, rm -r build, make clean, make, make flash.  Compiles and runs.
>> But still shows wrong version for m.version, and /store is still a mess.  Not sure if
>> I care about the m.version; what is going on with vfs?
>> Back to the TV...
>> Greg
>> Stephen Casner wrote:
>> Right.
>>     -- Steve
>> Ok, so master from the openvehicles clone?
>> Greg
>> Gre,
>> No, we left behind the v2.1 of esp-idf a while ago.  We're now on
>> master.
>>                                                        -- Steve
>> Mmm, never mind...  I realize we're still based on v2.1, right?
>> I've re-fetched stuff from the 2.1 branch, and still have the same results.  v3.0.0
>> listed as m.version, and junk in /store.
>> Now what?
>> Greg
>> Greg D. wrote:
>>      Ok, this is odd...  Are you sure esp-idf v3.1 is actually on Github?
>>      Tried re-fetching everything, and found this:
>>            greg at linux-0rpb:~/esp> git clone
>>            https://github.com/openvehicles/esp-idf.git
>>            Cloning into 'esp-idf'...
>>            remote: Counting objects: 44182, done.
>>            remote: Compressing objects: 100% (8/8), done.
>>            remote: Total 44182 (delta 0), reused 1 (delta 0), pack-reused
>>            44174
>>            Receiving objects: 100% (44182/44182), 50.53 MiB | 11.75
>>            MiB/s, done.
>>            Resolving deltas: 100% (31074/31074), done.
>>            greg at linux-0rpb:~/esp> cd esp-idf
>>            greg at linux-0rpb:~/esp/esp-idf> git branch -a
>>            * master
>>              remotes/origin/HEAD -> origin/master
>>              remotes/origin/feature/psram_malloc
>>              remotes/origin/master
>>              remotes/origin/release/v2.0
>>              remotes/origin/release/v2.1
>>              remotes/origin/release/v3.0
>>      Shouldn't there be a v3.1 listed there too?  Last entry is 3.0.
>>      Anyway, the first question is whether we have one problem or two...  Is my
>>      problem with /store related to v3.0 vs v3.1, or is it a separate problem
>>      on its own?  Do I simply need to clear flash and reload my config?  If so,
>>      what is the best way?
>>      Greg
>>      Mark Webb-Johnson wrote:
>>      Nope. Old hardware.
>> Out of ideas. I thought it just picked up the git version.
>>      On 15 Feb 2018, at 12:07 PM, Greg D. <gregd2350 at gmail.com>
>>      wrote:
>> No difference.
>> Are you on the new hardware?
>> Greg
>>      In your ovms directory:
>>      make clean
>> rm -rf build
>> make flash
>> That’s all I can think of.
>> Regards, Mark
>>      On 15 Feb 2018, at 11:59 AM, Greg D.
>>      <gregd2350 at gmail.com> wrote:
>> Yes, and yes.  The top entry exactly matches your log.
>> Greg
>>      And you’ve already ‘git pull’ and ‘git
>>      submodule update’ in that esp idf?
>> If you ‘git log’, you should get:
>>      commit
>>      8d8d62da9e58305c8f7f4792264f8cab3ffe104b
>>      (HEAD -> master, origin/master,
>>      origin/HEAD)
>> Merge: 5bf85d06 ca3faa61
>> Author: Mark Webb-Johnson
>> <mark at webb-johnson.net>
>> Date:   Tue Feb 13 13:27:55 2018 +0800
>>     Merge remote-tracking branch
>> 'espressif/master'
>> (which is where the 8d8d62da comes from)
>>      On 15 Feb 2018, at 11:42 AM, Greg D.
>> Yes and yes.
>>      git branch -a
>>      * master
>>      origin/master
>>      git remote -v
>>      origin
>>      (fetch)
>>      origin
>>      (push)
>> Greg
>>      In your esp idf directory, can
>>      you check ‘git branch -a’. Make
>>      sure you are on ‘master’ branch.
>>      Also ‘git remote -v’. Make sure
>>      you are on openvehicles clone.
>> Mark
>>      On 15 Feb 2018, at 10:24
>>      AM, Greg D.
>>      wrote:
>> Hi Mark,
>> So, I changed the
>> CONFIG_LWIP_SO_REUSE value and
>> did a make flash.  That
>> displayed another option,
>> default Yes, changed to no.
>> But, same result with /store.
>> One significant difference is
>> that you're on idf 3.1 and I'm
>> on 3.0...  (3.0.0/factory/main
>> build (idf
>> v3.0-dev-1781-g8d8d62da) Feb 14
>> 2018 18:12:05)
>> Did I miss a cog on this?
>> Greg
>>      My store seems ok:
>>      OVMS > vfs ls
>>      /store
>> ovms_config
>> obd2ecu
>> play
>> OVMS > metrics list
>> m.version
>> m.version
>>  3.0.0/factory/main
>> build (idf
>> v3.1-dev-391-g8d8d62da)
>> Feb 13 2018 14:05:21
>> Anybody else seeing this
>> issue?
>> Regarding the
>> CONFIG_LWIP_SO_REUSE, in
>> menuconfig you can use ‘/‘
>> to search for it. The
>> parameter is in Component
>> Config / LWIP.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180216/7dbe07af/attachment.htm>
