[Ovmsdev] Awfully quiet out there
Stephen Casner
casner at acm.org
Fri Feb 16 14:01:19 HKT 2018
Right.
On Thu, 15 Feb 2018, Greg D. wrote:
> Ok, so master from the openvehicles clone?
> Greg
> Stephen Casner wrote:
> Gre,
> No, we left behind the v2.1 of esp-idf a while ago. We're now on
> master.
> -- Steve
> Mmm, never mind... I realize we're still based on v2.1, right?
> I've re-fetched stuff from the 2.1 branch, and still have the same results. v3.0.0
> listed as m.version, and junk in /store.
> Now what?
> Greg
> Greg D. wrote:
> Ok, this is odd... Are you sure esp-idf v3.1 is actually on Github?
> Tried re-fetching everything, and found this:
> greg at linux-0rpb:~/esp> git clone
> https://github.com/openvehicles/esp-idf.git
> Cloning into 'esp-idf'...
> remote: Counting objects: 44182, done.
> remote: Compressing objects: 100% (8/8), done.
> remote: Total 44182 (delta 0), reused 1 (delta 0), pack-reused
> 44174
> Receiving objects: 100% (44182/44182), 50.53 MiB | 11.75
> MiB/s, done.
> Resolving deltas: 100% (31074/31074), done.
> greg at linux-0rpb:~/esp> cd esp-idf
> greg at linux-0rpb:~/esp/esp-idf> git branch -a
> * master
> remotes/origin/HEAD -> origin/master
> remotes/origin/feature/psram_malloc
> remotes/origin/master
> remotes/origin/release/v2.0
> remotes/origin/release/v2.1
> remotes/origin/release/v3.0
> Shouldn't there be a v3.1 listed there too? Last entry is 3.0.
> Anyway, the first question is whether we have one problem or two... Is my
> problem with /store related to v3.0 vs v3.1, or is it a separate problem
> on its own? Do I simply need to clear flash and reload my config? If so,
> what is the best way?
> Greg
> Mark Webb-Johnson wrote:
> Nope. Old hardware.
> Out of ideas. I thought it just picked up the git version.
> On 15 Feb 2018, at 12:07 PM, Greg D. <gregd2350 at gmail.com>
> wrote:
> No difference.
> Are you on the new hardware?
> Greg
> In your ovms directory:
> make clean
> rm -rf build
> make flash
> That’s all I can think of.
> Regards, Mark
> On 15 Feb 2018, at 11:59 AM, Greg D.
> <gregd2350 at gmail.com> wrote:
> Yes, and yes. The top entry exactly matches your log.
> Greg
> And you’ve already ‘git pull’ and ‘git
> submodule update’ in that esp idf?
> If you ‘git log’, you should get:
> commit
> 8d8d62da9e58305c8f7f4792264f8cab3ffe104b
> (HEAD -> master, origin/master,
> origin/HEAD)
> Merge: 5bf85d06 ca3faa61
> Author: Mark Webb-Johnson
> <mark at webb-johnson.net>
> Date: Tue Feb 13 13:27:55 2018 +0800
> Merge remote-tracking branch
> 'espressif/master'
> (which is where the 8d8d62da comes from)
> On 15 Feb 2018, at 11:42 AM, Greg D.
> Yes and yes.
> git branch -a
> * master
> origin/master
> git remote -v
> origin
> (fetch)
> origin
> (push)
> Greg
> In your esp idf directory, can
> you check ‘git branch -a’. Make
> sure you are on ‘master’ branch.
> Also ‘git remote -v’. Make sure
> you are on openvehicles clone.
> Mark
> On 15 Feb 2018, at 10:24
> AM, Greg D.
> wrote:
> Hi Mark,
> So, I changed the
> CONFIG_LWIP_SO_REUSE value and
> did a make flash. That
> displayed another option,
> default Yes, changed to no.
> But, same result with /store.
> One significant difference is
> that you're on idf 3.1 and I'm
> on 3.0... (3.0.0/factory/main
> build (idf
> v3.0-dev-1781-g8d8d62da) Feb 14
> 2018 18:12:05)
> Did I miss a cog on this?
> Greg
> My store seems ok:
> OVMS > vfs ls
> /store
> ovms_config
> obd2ecu
> play
> OVMS > metrics list
> m.version
> m.version
> 3.0.0/factory/main
> build (idf
> v3.1-dev-391-g8d8d62da)
> Feb 13 2018 14:05:21
> Anybody else seeing this
> issue?
> Regarding the
> CONFIG_LWIP_SO_REUSE, in
> menuconfig you can use ‘/‘
> to search for it. The
> parameter is in Component
> Config / LWIP.
