[Ovmsdev] Awfully quiet out there
    Thu Feb 15 11:47:31 HKT 2018
And you’ve already ‘git pull’ and ‘git submodule update’ in that esp idf?
If you ‘git log’, you should get:
commit 8d8d62da9e58305c8f7f4792264f8cab3ffe104b (HEAD -> master, origin/master, origin/HEAD)
Merge: 5bf85d06 ca3faa61
Author: Mark Webb-Johnson <mark at webb-johnson.net>
Date:   Tue Feb 13 13:27:55 2018 +0800
    Merge remote-tracking branch 'espressif/master'
(which is where the 8d8d62da comes from)
> On 15 Feb 2018, at 11:42 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Yes and yes.
> greg at linux-0rpb:~/esp/esp-idf> git branch -a
> * master
>   remotes/origin/HEAD -> origin/master
>   remotes/origin/feature/psram_malloc
>   remotes/origin/master
>   remotes/origin/release/v2.0
>   remotes/origin/release/v2.1
>   remotes/origin/release/v3.0
> greg at linux-0rpb:~/esp/esp-idf> git remote -v
> origin  https://github.com/openvehicles/esp-idf.git <https://github.com/openvehicles/esp-idf.git> (fetch)
> origin  https://github.com/openvehicles/esp-idf.git <https://github.com/openvehicles/esp-idf.git> (push)
> Greg
> Mark Webb-Johnson wrote:
>> In your esp idf directory, can you check ‘git branch -a’. Make sure you are on ‘master’ branch. Also ‘git remote -v’. Make sure you are on openvehicles clone.
>> Mark
>>> On 15 Feb 2018, at 10:24 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>> Hi Mark,
>>> So, I changed the CONFIG_LWIP_SO_REUSE value and did a make flash.  That displayed another option, default Yes, changed to no.  But, same result with /store.
>>> One significant difference is that you're on idf 3.1 and I'm on 3.0...  (3.0.0/factory/main build (idf v3.0-dev-1781-g8d8d62da) Feb 14 2018 18:12:05)
>>> Did I miss a cog on this?
>>> Greg
>>>> My store seems ok:
>>>> OVMS > vfs ls /store
>>>> ovms_config
>>>> obd2ecu
>>>> play
>>>> OVMS > metrics list m.version
>>>> m.version                                3.0.0/factory/main build (idf v3.1-dev-391-g8d8d62da) Feb 13 2018 14:05:21
>>>> Anybody else seeing this issue?
>>>> Regarding the CONFIG_LWIP_SO_REUSE, in menuconfig you can use ‘/‘ to search for it. The parameter is in Component Config / LWIP.
>>>> Regards, Mark.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180215/295ddd03/attachment.htm>
