[Ovmsdev] Awfully quiet out there
    Thu Feb 15 09:51:26 HKT 2018
My store seems ok:
OVMS > vfs ls /store
ovms_config
obd2ecu
play
OVMS > metrics list m.version
m.version                                3.0.0/factory/main build (idf v3.1-dev-391-g8d8d62da) Feb 13 2018 14:05:21
Anybody else seeing this issue?
Regarding the CONFIG_LWIP_SO_REUSE, in menuconfig you can use ‘/‘ to search for it. The parameter is in Component Config / LWIP.
> On 15 Feb 2018, at 4:25 AM, Greg D <gregd2350 at gmail.com> wrote:
> Updated ok, but I find that my config has been reset.  Poking around, I find that it /store seems to be whacked!
> <snip>
> ovms_config
> What happened?
> Also, I didn't see CONFIG_LWIP_SO_REUSE come up as a config item on the first make.  Is this one I need to edit manually?  Is that related to the above?
> Thanks,
> Greg
> Mark Webb-Johnson wrote:
>> I did the merge. Unfortunately, Espressif broke mDNS by changing the API, so I’ve also had to change OVMS v3 firmware to match.
>> This means developers need to update both ESP IDF and OVMS v3 source trees, before mDNS will compile.
>> cd  ~/esp/esp-idf
>> git pull
>> git submodule update
>> cd ~/ovms/vehicle/OVMS.V3
>> git pull
>> make
>> (changing paths as appropriate)
>> Or just disable the OVMS mDNS component if you are not using it.
>> It all compiles and seems to run for me now. There are a bunch of new configuration options. The only one I would like enabled (disabled by default) is CONFIG_LWIP_SO_REUSE=y.
>>> On 12 Feb 2018, at 3:02 PM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>> Mark,
>>> I think the merge you propose should work.  As I mentioned, I'm in
>>> discussion with @projectgus to get my code merged into the mainline.
>>>                                                        -- Steve
>>> On Mon, 12 Feb 2018, Mark Webb-Johnson wrote:
>>>> Steve,
>>>> I’m seeing weird heap corruption when I do PSRAM enabled builds and have heap debugging enabled. When I turn off the heap debugging, everything runs fine.
>>>> I notice this:
>>>> https://github.com/espressif/esp-idf/issues/1582 <https://github.com/espressif/esp-idf/issues/1582> <https://github.com/espressif/esp-idf/issues/1582 <https://github.com/espressif/esp-idf/issues/1582>>
>>>> and some associated fixes by Espressif to master.
>>>> Any issues with us merging in upstream Espress ESP IDF master to our clone? See if that resolves the problem?
>>>> Regards, Mark.
>>>>> On 12 Feb 2018, at 2:15 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>>>> It's been several days since I've seen any messages on this list.  I
>>>>> suppose that Mark has been occupied by the hardware changes.  Myself,
>>>>> I've finished the things I was working on (with the possible exception
>>>>> of adding an immediate-send option back into Mongoose), but I've
>>>>> entered a PR to get the code I added to esp-idf to support the
>>>>> per-task heap allocation commands accepted into the mainline and have
>>>>> been refining the code in response to change requests.
>>>>>                                                       -- Steve
>>>>> OvmsDev mailing list
>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180215/c2655ae6/attachment.htm>
