[Ovmsdev] Auto start/init
Tue Feb 27 02:23:22 HKT 2018
Greg,
this handling is based on the assumption we can have the QC set the initial pass phrase / module password.
It also protects a power user / developer against forgetting to configure a pass phrase after a full reflash of the module.
Normal users will update OTA / by SD card, so will not lose the pass phrase once set.
Let's see if QC can do that. If not, we can fallback to a default password instead.
Am 26.02.2018 um 01:46 schrieb Greg D.:
> I understand the desire for security, but how does one set the password
> the first time?  Instead, how about about using a default passkey if the
> module password is not set?  That keeps the web interface closed to the
> casual passerby, but allows initial connection to those with the
> physical module's accompanying documentation.
> We really ought to be making this easier to configure than the v2
> module, where it one needed wrestle with SIM cards, accounts, and
> activation headaches in order use SMS messages.  USB serial consoles are
> better, but they still aren't all that user friendly.  We have a
> wonderful web interface; we should be able to use it out of the box.
> Greg
> Michael Balzer wrote:
>> The auto wifi ap mode does a fallback to "OVMS" with the module password if no AP network is configured. It does not start the AP mode if the password is empty.
>> So in order to enable the AP mode for configuration, it's sufficient to set the module password and leave all auto configs to their defaults.
