[Ovmsdev] /store gone
Mon Feb 26 13:47:41 HKT 2018
I think that makes you the ‘make guru’.
Thanks, Mark.
> On 25 Feb 2018, at 6:30 PM, Michael Balzer <dexter at expeedo.de> wrote:
> I just pushed a solution for this.
> Am 24.02.2018 um 21:52 schrieb Stephen Casner:
>> This needs some help, but I don't qualify as a 'make' guru.
>> Just now I pulled to get the new ovms_time and ran 'make' (within
>> emacs, as I usually do so I can jump to the source files for errors).
>> That compiled just the new module as expected. Then I wanted to run
>> it, so in the shell I did "make flash monitor". That proceded to run
>> GENCONFIG and recompile everything.
>> While working on the updates last evening I observed that every time I
>> did "make flash monitor" it would recompile ovms_version and link even
>> though I had just done a 'make' beforehand.
>> -- Steve
>> On Thu, 22 Feb 2018, Mark Webb-Johnson wrote:
>>> Michael,
>>> Our own version is set in main/ovms.h as:
>>> #define OVMS_VERSION "3.0.990"
>>> That is used to generate metrics, on boot.
>>> I have just committed (and pushed) a re-work of this to do something similar to what you show here. Downside is that the main/ovms_version module has to be rebuilt each build.
>>> OVMS > metrics list m.version
>>> m.version 3.0.990-6-ga45e575/factory/main build (idf v3.1-dev-392-g3d5f7b3e) Feb 22 2018 11:16:23
>>> Any ‘make’ gurus out there that want to improve it, please go ahead. Perhaps we can somehow depend it on the main ovms.o (so it only builds when that changes)?
>>> Regards, Mark
>>>> On 17 Feb 2018, at 7:26 AM, Michael Balzer <dexter at expeedo.de> <mailto:dexter at expeedo.de> wrote:
>>>> That's set at…
>>>> balzer at leela:~/esp/esp-idf> git show v3.1-dev
>>>> commit 22489d70214a5b7650ab197ffd6ab73e9c50a772
>>>> Merge: c4448714 f58c5b21
>>>> Author: Jiang Jiang Jian <jack at espressif.com> <mailto:jack at espressif.com> <mailto:jack at espressif.com> <mailto:jack at espressif.com>
>>>> Date: Fri Dec 1 22:06:43 2017 +0800
>>>> Merge branch 'bugfix/wdt_periph_enable' into 'master'
>>>> watchdogs: make sure timer group peripherals are enabled
>>>> See merge request !1623
>>>> OvmsDev mailing list
>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180226/79a29615/attachment.html>
