[Ovmsdev] Moving to a production cycle
Sat Feb 24 20:54:50 HKT 2018
I’m not sure that Wifi MAC helps. That is broadcast as part of the WiFi station announcement, so using it as the password is really not any more secure than a fixed OVMS password.
Printing the wifi MAC also would be troublesome, because it would have to be entered into some printing program, and labels individually printed. Messy. Hand-written would not be good.
A better approach would be to come at it from the other way. Have the serial numbers / password stickers pre-printed in a large batch. Then, have the factory enter them into the number into the module during initial flashing / QC tests.
There is BLK3 of eFuses, but I find those scary. Supposedly it is not used (other than for a custom MAC address), and there are 192/256 bits available. That would be a one-time flash. We could store the serial number as a locally administered MAC address there.
It could also go into the flash as a configured parameter. That would be read/write (allowing someone to change the serial number).
BLK3 is probably the correct way of doing things, but very scary. That is a one time write (it literally sends too much current down a little wire in the chip - burning it out), and not so easy to debug the code ;-)
> On 24 Feb 2018, at 5:21 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Greg, Mark,
> I'm a bit concerned about an initially open Wifi access.
> I know we're not targeting a mass market, but security is always important, especially for a system that can potentially control a car.
> We need to be -and stay- aware this may introduce a way to hack & hijack the system. You would for example scan for new OVMS wifi networks, do an automatic
> passkey change to get access, then get the module to install a trojan firmware that mimicks the original behaviour (root kit style) and voila, you've got
> another bitcoin miner. A normal user will never recognize something's fishy.
> With our current OTA function that's an unlikely attack vector, you would need to either control the GSM cell / DNS to redirect the download to your trojan site
> or have hacked the openvehicles.com server to deliver your trojan firmware. But things will evolve.
> Some users may also not care about the Wifi access (i.e. using just Bluetooth / USB / GSM) and then not be aware it's actually active & open.
> Is it too expensive to print the Wifi MAC or serial no. onto some label or document for the user?
> If so we should at least make this very clear in the user documentation.
> Btw, the same password could be used as the default module password, or we could use the module password for both purposes.
> Am 22.02.2018 um 05:52 schrieb Mark Webb-Johnson:
>>> There probably isn't a
>>> need for a custom SSID based on MAC or other serialization; that would
>>> only be necessary if configuring multiple modules at the same time in
>>> the same place.  Use case?
>> Yep. My thoughts exactly.
>>> it might be
>>> a good idea to have a required step of the configuration procedure be to
>>> force a passkey change and re-connect on the part of the user.
>> Yep. If we ask them to specify the AP name, and new password, then that resolves both problems.
