[Ovmsdev] /store gone (was: Re: Awfully quiet out there)
Thu Feb 22 11:22:03 HKT 2018
Michael,
Our own version is set in main/ovms.h as:
#define OVMS_VERSION "3.0.990"
That is used to generate metrics, on boot.
I have just committed (and pushed) a re-work of this to do something similar to what you show here. Downside is that the main/ovms_version module has to be rebuilt each build.
OVMS > metrics list m.version
m.version 3.0.990-6-ga45e575/factory/main build (idf v3.1-dev-392-g3d5f7b3e) Feb 22 2018 11:16:23
Any ‘make’ gurus out there that want to improve it, please go ahead. Perhaps we can somehow depend it on the main ovms.o (so it only builds when that changes)?
> On 17 Feb 2018, at 7:26 AM, Michael Balzer <dexter at expeedo.de> wrote:
> That's set at…
> balzer at leela:~/esp/esp-idf> git show v3.1-dev
> commit 22489d70214a5b7650ab197ffd6ab73e9c50a772
> Merge: c4448714 f58c5b21
> Author: Jiang Jiang Jian <jack at espressif.com> <mailto:jack at espressif.com>
> Date: Fri Dec 1 22:06:43 2017 +0800
> Merge branch 'bugfix/wdt_periph_enable' into 'master'
> watchdogs: make sure timer group peripherals are enabled
> See merge request !1623
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180222/7055a88b/attachment-0001.html>
