[Ovmsdev] /store gone
Sat Feb 17 11:08:08 HKT 2018
I get the same error message if I try "vfs cat /store/scripts" (which
is a directory), so I don't think that message indicates anything
worse for you.  If the recovery approach is to wipe flash, what harm
could there be in trying to write something in the config?
On Fri, 16 Feb 2018, Greg D. wrote:
> That would have helped.  Also, shouldn't a 'stat' of it return something
> useful?  That error about not being able to open it leaves me wondering
> about what is safe to do at this point.
> Greg
> Stephen Casner wrote:
> > On Sat, 17 Feb 2018, Mark Webb-Johnson wrote:
> >> Ovms_config is a directory. Don't think you can cat it.
> > Oh, right.  Perhaps vfs ls should add a trailing '/'?
> >                                                         -- Steve
