[Ovmsdev] Awfully quiet out there
Thu Feb 15 12:32:06 HKT 2018
Nope. Old hardware.
Out of ideas. I thought it just picked up the git version.
> On 15 Feb 2018, at 12:07 PM, Greg D. <gregd2350 at gmail.com> wrote:
> No difference.
> Are you on the new hardware?
> Greg
> Mark Webb-Johnson wrote:
>> In your ovms directory:
>> make clean
>> rm -rf build
>> make flash
>> That’s all I can think of.
>> Regards, Mark
>>> On 15 Feb 2018, at 11:59 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>> Yes, and yes. The top entry exactly matches your log.
>>> Greg
>>>> And you’ve already ‘git pull’ and ‘git submodule update’ in that esp idf?
>>>> If you ‘git log’, you should get:
>>>> commit 8d8d62da9e58305c8f7f4792264f8cab3ffe104b (HEAD -> master, origin/master, origin/HEAD)
>>>> Merge: 5bf85d06 ca3faa61
>>>> Author: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>>>> Date: Tue Feb 13 13:27:55 2018 +0800
>>>> Merge remote-tracking branch 'espressif/master'
>>>> (which is where the 8d8d62da comes from)
>>>> Regards, Mark.
>>>>> On 15 Feb 2018, at 11:42 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>>> Yes and yes.
>>>>> greg at linux-0rpb:~/esp/esp-idf> git branch -a
>>>>> * master
>>>>> remotes/origin/HEAD -> origin/master
>>>>> remotes/origin/feature/psram_malloc
>>>>> remotes/origin/master
>>>>> remotes/origin/release/v2.0
>>>>> remotes/origin/release/v2.1
>>>>> remotes/origin/release/v3.0
>>>>> greg at linux-0rpb:~/esp/esp-idf> git remote -v
>>>>> origin https://github.com/openvehicles/esp-idf.git <https://github.com/openvehicles/esp-idf.git> (fetch)
>>>>> origin https://github.com/openvehicles/esp-idf.git <https://github.com/openvehicles/esp-idf.git> (push)
>>>>> Greg
>>>>>> In your esp idf directory, can you check ‘git branch -a’. Make sure you are on ‘master’ branch. Also ‘git remote -v’. Make sure you are on openvehicles clone.
>>>>>> Mark
>>>>>>> On 15 Feb 2018, at 10:24 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>>>>> Hi Mark,
>>>>>>> So, I changed the CONFIG_LWIP_SO_REUSE value and did a make flash. That displayed another option, default Yes, changed to no. But, same result with /store.
>>>>>>> One significant difference is that you're on idf 3.1 and I'm on 3.0... (3.0.0/factory/main build (idf v3.0-dev-1781-g8d8d62da) Feb 14 2018 18:12:05)
>>>>>>> Did I miss a cog on this?
>>>>>>> Greg
>>>>>>>> My store seems ok:
>>>>>>>> OVMS > vfs ls /store
>>>>>>>> ovms_config
>>>>>>>> obd2ecu
>>>>>>>> play
>>>>>>>> OVMS > metrics list m.version
>>>>>>>> m.version 3.0.0/factory/main build (idf v3.1-dev-391-g8d8d62da) Feb 13 2018 14:05:21
>>>>>>>> Anybody else seeing this issue?
>>>>>>>> Regarding the CONFIG_LWIP_SO_REUSE, in menuconfig you can use ‘/‘ to search for it. The parameter is in Component Config / LWIP.
>>>>>>>> Regards, Mark.
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180215/324ae2af/attachment.html>
