[Ovmsdev] Awfully quiet out there
Thu Feb 15 12:00:43 HKT 2018
In your ovms directory:
make clean
rm -rf build
make flash
That’s all I can think of.
> On 15 Feb 2018, at 11:59 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Yes, and yes. The top entry exactly matches your log.
> Greg
> Mark Webb-Johnson wrote:
>> And you’ve already ‘git pull’ and ‘git submodule update’ in that esp idf?
>> If you ‘git log’, you should get:
>> commit 8d8d62da9e58305c8f7f4792264f8cab3ffe104b (HEAD -> master, origin/master, origin/HEAD)
>> Merge: 5bf85d06 ca3faa61
>> Author: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>> Date: Tue Feb 13 13:27:55 2018 +0800
>> Merge remote-tracking branch 'espressif/master'
>> (which is where the 8d8d62da comes from)
>>> On 15 Feb 2018, at 11:42 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>> Yes and yes.
>>> greg at linux-0rpb:~/esp/esp-idf> git branch -a
>>> * master
>>> remotes/origin/HEAD -> origin/master
>>> remotes/origin/feature/psram_malloc
>>> remotes/origin/master
>>> remotes/origin/release/v2.0
>>> remotes/origin/release/v2.1
>>> remotes/origin/release/v3.0
>>> greg at linux-0rpb:~/esp/esp-idf> git remote -v
>>> origin https://github.com/openvehicles/esp-idf.git <https://github.com/openvehicles/esp-idf.git> (fetch)
>>> origin https://github.com/openvehicles/esp-idf.git <https://github.com/openvehicles/esp-idf.git> (push)
>>> Greg
>>>> In your esp idf directory, can you check ‘git branch -a’. Make sure you are on ‘master’ branch. Also ‘git remote -v’. Make sure you are on openvehicles clone.
>>>> Mark
>>>>> On 15 Feb 2018, at 10:24 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>>> Hi Mark,
>>>>> So, I changed the CONFIG_LWIP_SO_REUSE value and did a make flash. That displayed another option, default Yes, changed to no. But, same result with /store.
>>>>> One significant difference is that you're on idf 3.1 and I'm on 3.0... (3.0.0/factory/main build (idf v3.0-dev-1781-g8d8d62da) Feb 14 2018 18:12:05)
>>>>> Did I miss a cog on this?
>>>>> Greg
>>>>>> My store seems ok:
>>>>>> OVMS > vfs ls /store
>>>>>> ovms_config
>>>>>> obd2ecu
>>>>>> play
>>>>>> OVMS > metrics list m.version
>>>>>> m.version 3.0.0/factory/main build (idf v3.1-dev-391-g8d8d62da) Feb 13 2018 14:05:21
>>>>>> Anybody else seeing this issue?
>>>>>> Regarding the CONFIG_LWIP_SO_REUSE, in menuconfig you can use ‘/‘ to search for it. The parameter is in Component Config / LWIP.
>>>>>> Regards, Mark.
>>>>> OvmsDev mailing list
>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180215/1c13567d/attachment.html>
