[Ovmsdev] Awfully quiet out there
Thu Feb 15 11:04:41 HKT 2018
In your esp idf directory, can you check ‘git branch -a’. Make sure you are on ‘master’ branch. Also ‘git remote -v’. Make sure you are on openvehicles clone.
Mark
> On 15 Feb 2018, at 10:24 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi Mark,
> So, I changed the CONFIG_LWIP_SO_REUSE value and did a make flash. That displayed another option, default Yes, changed to no. But, same result with /store.
> One significant difference is that you're on idf 3.1 and I'm on 3.0... (3.0.0/factory/main build (idf v3.0-dev-1781-g8d8d62da) Feb 14 2018 18:12:05)
> Did I miss a cog on this?
> Greg
> Mark Webb-Johnson wrote:
>> My store seems ok:
>> OVMS > vfs ls /store
>> ovms_config
>> obd2ecu
>> play
>> OVMS > metrics list m.version
>> m.version 3.0.0/factory/main build (idf v3.1-dev-391-g8d8d62da) Feb 13 2018 14:05:21
>> Anybody else seeing this issue?
>> Regarding the CONFIG_LWIP_SO_REUSE, in menuconfig you can use ‘/‘ to search for it. The parameter is in Component Config / LWIP.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180215/2fe78c86/attachment.html>
