[Ovmsdev] Javascript
Sun Dec 23 16:38:25 HKT 2018
Steve,
thanks for confirming, I've added an issue on this:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/179
Regarding the bug: lucky find due to "PC" in the new backup usage string.
No need to explain, we're all human.
Am 23.12.18 um 01:53 schrieb Stephen Casner:
> Michael,
> Thank you! With the (small) font I'm using I could not easily see
> that the closing double quote was not the 7-bit ASCII one. I had
> copy/pasted that from Mark's message, so some software must have done
> him a favor when he prepared his message. I hate "smart" quotes.
> Thanks also for fixing the usage string expansion. I don't know how
> to explain my writing of the wrong function other than perhaps I was
> copy/pasting from some other file of mine that worked differently or
> the design evolved and I didn't change the function. The bug was not
> detected because every instance of '$' was followed by 'C' so
> find_first_of("$C") still found the right position and the text in
> usage strings was all lower case so no other 'C' was found. There's
> only one instance of $G used (in the "power" command) and it follows a
> $C so again the wrong function still found the right position.
> -- Steve
> On Sun, 23 Dec 2018, Michael Balzer wrote:
>> Steve...
>>> OVMS# vfs cat /store/scripts/helloworld.js
>>> OvmsPrint("Hello world!\n*"*);
>> ...is that closing quote really a typographic one? If so, try replacing that by a straight one.
>> Am 22.12.18 um 23:50 schrieb Stephen Casner:
>>> Well, I have tried several stages of rebuilding, but I still get an
>>> immediate crash from duktape.
>>> First I updated sources for ovms and esp-idf (the previous pull was
>>> October 29). Still crashed.
>>> Then I changed from RELEASE to DEBUG to be like sdkconfig.default.hw31
>>> but that failed to link because I still had bluetooth configured so
>>> there was not enough space in IRAM, so I removed bluetooth and made
>>> clean. Still crashed.
>>> Then I backed off to straight sdkconfig.default.hw31, though the make
>>> procedure then added some more defaults that should be checked in.
>>> Still crashed.
>>> The most obvious question is whether there is something wrong with my
>>> javascript file so that duktape is legitimately considering it in
>>> error, but the source looks clean:
>>> OvmsPrint("Hello world!\n");
>>> OVMS#
>>> I don't have any other ideas yet.
>>> -- Steve
>>> On Sat, 22 Dec 2018, Stephen Casner wrote:
>>>> Michael,
>>>> I used the same sequence of commands that you did. The only
>>>> difference is that I did not capitalize World and I did include an
>>>> exclamation point after it (since I did copy/paste from Mark's
>>>> message).
>>>> Maybe it is an insufficient free memory problem. But I just tried
>>>> again via an ssh console with this starting condition:
>>>> Free 8-bit 91352/230700, 32-bit 1236/3144, SPIRAM 4032872/4194252
>>>> That should be sufficient.
>>>> Attached is a diff of sdkconfig.default.hw31 to my sdkconfig. The
>>>> only thing I noticed that might be an explanation is the optimization
>>>> level set to RELEASE vs DEBUG.
>>>> -- Steve
>>>> On Sat, 22 Dec 2018, Michael Balzer wrote:
>>>>> Steve,
>>>>> I just tried this:
>>>>> OVMS# vfs append 'OvmsPrint("Hello World\n");' /store/scripts/helloworld.js
>>>>> OVMS# . helloworld.js
>>>>> Hello World
>>>>> OVMS#
>>>>> So no, the blank line isn't necessary.
>>>>> Regards,
>>>>> Michael
>>>>> Am 22.12.18 um 09:14 schrieb Stephen Casner:
>>>>>> Mark,
>>>>>> There is a blank line at the end of your script that I don't have.
>>>>>> Perhaps that is required for javascript? I'll try that soon. On the
>>>>>> other hand, crashing when the input format isn't as desired is not the
>>>>>> best error handling approach.
>>>>>> I do have some deviations from sdkconfig.default.hw31, but not in the
>>>>>> spec for the duktape library.
>>>>>> -- Steve
>>>>>> On Sat, 22 Dec 2018, Mark Webb-Johnson wrote:
>>>>>>> Steve,
>>>>>>> I get this:
>>>>>>> OVMS# vfs cat /sd/helloworld.js
>>>>>>> OvmsPrint("Hello world\n");
>>>>>>> OVMS# . /sd/helloworld.js
>>>>>>> Hello world
>>>>>>> Maybe your SDKCONFIG different than mine? I am using the sdkconfig.default.hw31.
>>>>>>> Regards, Mark.
