Stephen Casner
casner at acm.org
Sun Dec 23 06:56:46 HKT 2018
Last night the OVMS wifi claimed to be up while my router said OVMS
was not active (which I interpret to mean not associated). I was
expecting the condition of OVMS to deteriorate further such that the
mg_connect error loop would occur again, but this morning wifi
connectivity was working again and OVMS had not rebooted. I guess the
wifi reception improved enough to associate again.
On Fri, 21 Dec 2018, Stephen Casner wrote:
> I'm still having poor wifi performance with 3.1.011. As with earlier
> releases, when I find OVMS is not responsive over wifi and connect to
> the serial port I find this error repeating:
> E (57630676) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
> E (57630676) ovms-server-v2: Status: Error: Connection failed
> I (57637436) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
> I (57637436) ovms-server-v2: Status: Connecting...
> E (57650836) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
> E (57650836) ovms-server-v2: Status: Error: Connection failed
> I (57657436) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
> I (57657436) ovms-server-v2: Status: Connecting...
> This can be cured by "wifi mode off" then "wifi mode client ..." to
> bring wifi back up again. The really bad part is that the wifi system
> does not recognize that it has lost connectivity so the primary
> interface does not switch over to the modem.
> The "cannot parse address" error suggests that Mongoose is in some
> strange state. I've put in some debugging code to investigate just
> how the parse is failing, and I'm waiting for it to get back into this
> error loop.
> Meanwhile, my ssh connection to OVMS dropped and my router says the
> OVMS station is down, so I went to hook up to the serial console
> again. This mongoose complaint is not happening (yet). But the wifi
> does not recognize that it has no association with my router:
> OVMS# wifi status
> Power: on
> Mode: Client mode
> STA SSID: Revelstoke (-81 dBm)
> MAC: 30:ae:a4:43:9c:28
> IP: 192.168.1.74/255.255.255.0
> GW: 192.168.1.254
> OVMS# network status
> Interface#2: pp2 (ifup=1 linkup=1)
> IPv4: 10.170.41.247/255.255.255.255 gateway 10.64.64.64
> Interface#1: st1 (ifup=1 linkup=1)
> IPv4: 192.168.1.74/255.255.255.0 gateway 192.168.1.254
> DNS: 8.8.8.8 8.8.4.4
> Default Interface: st1 (192.168.1.74/255.255.255.0 gateway 192.168.1.254)
> OVMS# server v2 status
> State: Connected
> OVMS V2 login successful, and crypto channel established
> OVMS#
> Even though server-v2 sends updates periodically, the failed wifi is
> not detected. So I guess that is the root problem. I'm expecting
> that after some time the mongoose state will deteriorate such that the
> parse error occurs again and I can at least investigate that part.
> -- Steve
