[Ovmsdev] Javascript
Sun Dec 23 08:53:58 HKT 2018
Michael,
Thank you!  With the (small) font I'm using I could not easily see
that the closing double quote was not the 7-bit ASCII one.  I had
copy/pasted that from Mark's message, so some software must have done
him a favor when he prepared his message.  I hate "smart" quotes.
Thanks also for fixing the usage string expansion.  I don't know how
to explain my writing of the wrong function other than perhaps I was
copy/pasting from some other file of mine that worked differently or
the design evolved and I didn't change the function.  The bug was not
detected because every instance of '$' was followed by 'C' so
find_first_of("$C") still found the right position and the text in
usage strings was all lower case so no other 'C' was found.  There's
only one instance of $G used (in the "power" command) and it follows a
$C so again the wrong function still found the right position.
On Sun, 23 Dec 2018, Michael Balzer wrote:
> Steve...
> > OVMS# vfs cat /store/scripts/helloworld.js
> > OvmsPrint("Hello world!\n*"*);
> ...is that closing quote really a typographic one? If so, try replacing that by a straight one.
> Am 22.12.18 um 23:50 schrieb Stephen Casner:
> > Well, I have tried several stages of rebuilding, but I still get an
> > immediate crash from duktape.
> > First I updated sources for ovms and esp-idf (the previous pull was
> > October 29).  Still crashed.
> > Then I changed from RELEASE to DEBUG to be like sdkconfig.default.hw31
> > but that failed to link because I still had bluetooth configured so
> > there was not enough space in IRAM, so I removed bluetooth and made
> > clean.  Still crashed.
> > Then I backed off to straight sdkconfig.default.hw31, though the make
> > procedure then added some more defaults that should be checked in.
> > Still crashed.
> > The most obvious question is whether there is something wrong with my
> > javascript file so that duktape is legitimately considering it in
> > error, but the source looks clean:
> > OvmsPrint("Hello world!\n");
> > OVMS#
> > I don't have any other ideas yet.
> >                                                         -- Steve
> > On Sat, 22 Dec 2018, Stephen Casner wrote:
> >> Michael,
> >> I used the same sequence of commands that you did.  The only
> >> difference is that I did not capitalize World and I did include an
> >> exclamation point after it (since I did copy/paste from Mark's
> >> message).
> >> Maybe it is an insufficient free memory problem.  But I just tried
> >> again via an ssh console with this starting condition:
> >> Free 8-bit 91352/230700, 32-bit 1236/3144, SPIRAM 4032872/4194252
> >> That should be sufficient.
> >> Attached is a diff of sdkconfig.default.hw31 to my sdkconfig.  The
> >> only thing I noticed that might be an explanation is the optimization
> >> level set to RELEASE vs DEBUG.
> >>                                                         -- Steve
> >> On Sat, 22 Dec 2018, Michael Balzer wrote:
> >>> Steve,
> >>> I just tried this:
> >>> OVMS# vfs append 'OvmsPrint("Hello World\n");' /store/scripts/helloworld.js
> >>> OVMS# . helloworld.js
> >>> Hello World
> >>> OVMS#
> >>> So no, the blank line isn't necessary.
> >>> Regards,
> >>> Michael
> >>> Am 22.12.18 um 09:14 schrieb Stephen Casner:
> >>>> Mark,
> >>>> There is a blank line at the end of your script that I don't have.
> >>>> Perhaps that is required for javascript?  I'll try that soon.  On the
> >>>> other hand, crashing when the input format isn't as desired is not the
> >>>> best error handling approach.
> >>>> I do have some deviations from sdkconfig.default.hw31, but not in the
> >>>> spec for the duktape library.
> >>>>                                                         -- Steve
> >>>> On Sat, 22 Dec 2018, Mark Webb-Johnson wrote:
> >>>>> Steve,
> >>>>> I get this:
> >>>>> OVMS# vfs cat /sd/helloworld.js
> >>>>> OvmsPrint("Hello world\n");
> >>>>> OVMS# . /sd/helloworld.js
> >>>>> Hello world
> >>>>> Maybe your SDKCONFIG different than mine? I am using the sdkconfig.default.hw31.
> >>>>> Regards, Mark.
