[Ovmsdev] Garbage in /store
Sun Dec 23 04:31:31 HKT 2018
Michael,
Glad you figured that out.  I had looked at the code to see if that
gave me any hints as to what kind of <path> argument was required, but
I could not tell from the code where the error was occurring.
I notice that some other commands use <vfspath> for the help string to
be more specific.  Would that be a good idea for config backup?
On Sat, 22 Dec 2018, Michael Balzer wrote:
> Steve,
> I missed the case of a non-existent "/store/events" directory.
> I'll fix that now, to backup without updating, do "vfs mkdir /store/events".
> Am 22.12.18 um 02:13 schrieb Stephen Casner:
> > What kind of <path> is expected in "config backup <path>"?  I tried
> > "/sd/config-20181221.zip" and "config-20181221.zip" but both resulted
> > in "Error: zip failed: No such file or directory".  Manually creating
> > the empty file "/sd/config-20181221.zip" first did not help.
> >                                                         -- Steve
