[Ovmsdev] Javascript
Sat Dec 22 23:22:45 HKT 2018
Sort of a mini "node.js"? That will take the scripting capabilities to a new level, looking forward to this.
Just saw duktape also has a node.js like module loader in the extras directory, supplying the require() function etc. -- very nice.
There are some embedded real node.js implementations, even one running on duktape, but that may be a bit over the top ;-)
Am 22.12.18 um 14:03 schrieb Mark Webb-Johnson:
> The location module publishes a duktape interface “OvmsLocationStatus”. Passed a string location name, it returns true if the vehicle is currently in that
> location.
> The command module publishes a duktape interface “OvmsCommand” that allow an arbitrary command to be executed.
> The metrics module publishes duktape interfaces “OvmsMetricValue” and “OvmsMetricFloat” to retrieve the value of the passed metric name (string).
> The vehicle module issues a number of events regarding charge state:
> * vehicle.charge.start when charging starts
> * vehicle.charge.stop when charging ends
> * vehicle.charge.prepare when the charge port door is opened
> * vehicle.charge.finish when the charge port door is closed
> * vehicle.charge.pilot.on when the pilot signal is received
> * vehicle.charge.pilot.off when the pilot signal goes off
> * vehicle.charge.state when charge state changes
> The idea is to hook into the required charge event, to run a javascript script. For example, “vehicle.charge.pilot.on” to pickup the pilot signal. That script
> can then check the location state, and possibly other metrics, and act appropriately (such as issuing commands to cool down, etc).
> That is how it should work today. But is largely untested. As you have found, if duktape hits a fatal error in the script, it aborts and the module reboots.
> I really want to re-work this so that there is a duktape task always running. My idea is to hook it in to the ‘auto’ system Michael developed (so it can be
> configured to run or not, and also be disabled if the system repeatedly crashes during startup). That task would load all the scripts and run always. Then
> events would be fed into that task using the javascript event system. We can also more elegantly handle script exceptions and reload when scripts change.
> Javascript then runs alongside the rest of the system - timers can be used, and code logic / data values can persists between events. We can also use SPIRAM
> rather than internal RAM. I am working on this, but I want to get the architecture right.
>> On 21 Dec 2018, at 10:14 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> I’m travelling at the moment. Should be back to a PC tomorrow and I will try to give you a full reply.
>> I think JavaScript is the way to do this. That was the intent anyway. The issue is that I think the way we have the JavaScript at the moment is not correct.
>> It needs to be a task that runs continuously, and events fed into it. At the moment it is launched for each event. If a task, then it can have timers and
>> full functionality.
>> Regards, Mark
>>> On 21 Dec 2018, at 9:56 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>> Mark has asserted that the ACC functions could be implemented with
>>> events and scripting. I'm trying to investigate how to do this, so
>>> I'm reaching back a few months to this message about javascript
>>> support. When I try Mark's helloworld.js example I get an immediate
>>> crash, as shown below. Any idea why?
>>> -- Steve
>>> OVMS# vfs cat /store/scripts/helloworld.js
>>> OvmsPrint("Hello world!\n”);
>>> OVMS# . helloworld.js
>>> abort() was called at PC 0x401b8892 on core 1
>>> 0x401b8892: duk_default_fatal_handler at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:27339
>>> Backtrace: 0x40097f6b:0x3ffe15b0 0x400980c3:0x3ffe15d0 0x401b8892:0x3ffe15f0 0x402481dd:0x3ffe1610 0x401ba5c7:0x3ffe1630 0x401c1ae9:0x3ffe1650
>>> 0x401c89da:0x3ffe1670 0x401c9e6b:0x3ffe1860 0x401c9ed1:0x3ffe1880 0x401ce2cf:0x3ffe18b0 0x400f0488:0x3ffe18d0 0x400f05b9:0x3ffe18f0 0x400e5766:0x3ffe1940
>>> 0x400e5849:0x3ffe1980 0x400e589a:0x3ffe19c0 0x400f06bf:0x3ffe19e0 0x400f3a8b:0x3ffe1a00 0x400f3c2e:0x3ffe1a60 0x400f06f3:0x3ffe1ad0 0x4024388e:0x3ffe1af0
>>> 0x400e3295:0x3ffe1b10 0x400e8635:0x3ffe1b40 0x400e87fd:0x3ffe1b70 0x400e3151:0x3ffe1b90 0x400e3160:0x3ffe1bb0 0x400f27b9:0x3ffe1bd0
>>> 0x40097f6b: invoke_abort at /Users/casner/src/github/esp-idf/components/esp32/panic.c:670
>>> 0x400980c3: abort at /Users/casner/src/github/esp-idf/components/esp32/panic.c:670
>>> 0x402481dd: duk_fatal_raw at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:27715
>>> 0x401ba5c7: duk__uncaught_minimal at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:27339
>>> (inlined by) duk_err_longjmp at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:49682
>>> 0x401c1ae9: duk_throw_raw at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:27339
>>> 0x401c89da: duk_js_compile at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:27339
>>> 0x401c9e6b: duk__do_compile at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:27339
>>> 0x401c9ed1: duk_compile_raw at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:27339
>>> 0x401ce2cf: duk_eval_raw at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:27339
>>> 0x400f0488: script_ovms(bool, int, OvmsWriter*, char const*, __sFILE*, bool) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_script.cpp:77
>>> 0x400f05b9: script_run(int, OvmsWriter*, OvmsCommand*, int, char const* const*) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_script.cpp:133
>>> 0x400e5766: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_command.cpp:162
>>> 0x400e5849: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_command.cpp:162
>>> 0x400e589a: OvmsCommandApp::Execute(int, OvmsWriter*, int, char const* const*) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_command.cpp:162
>>> 0x400f06bf: Execute(microrl*, int, char const* const*) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_shell.cpp:48
>>> 0x400f3a8b: new_line_handler at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/microrl/microrl.c:620
>>> 0x400f3c2e: microrl_insert_char at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/microrl/microrl.c:668
>>> 0x400f06f3: OvmsShell::ProcessChar(char) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_shell.cpp:73
>>> 0x4024388e: OvmsShell::ProcessChars(char const*, int) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_shell.cpp:80 (discriminator 2)
>>> 0x400e3295: ConsoleAsync::HandleDeviceEvent(void*) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/console_async.cpp:170
>>> 0x400e8635: OvmsConsole::Poll(unsigned int, void*) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_console.cpp:151
>>> 0x400e87fd: OvmsConsole::Service() at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/ovms_console.cpp:131 (discriminator 1)
>>> 0x400e3151: ConsoleAsync::Service() at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/console_async.cpp:81
>>> 0x400e3160: non-virtual thunk to ConsoleAsync::Service() at ??:?
>>> 0x400f27b9: TaskBase::Task(void*) at /Users/casner/src/github/ovms/vehicle/OVMS.V3/main/task_base.cpp:156
>>> Entering gdb stub now.
>>> $T0b#e6GNU gdb (crosstool-NG) 7.10
>>> Copyright (C) 2015 Free Software Foundation, Inc.
>>> Reading symbols from /Users/casner/src/github/ovms/vehicle/OVMS.V3/build/ovms3.elf...done.
>>> Remote debugging using /dev/cu.SLAB_USBtoUART
>>> 0x40097f6b in invoke_abort () at /Users/casner/src/github/esp-idf/components/esp32/panic.c:140
>>> 140 *((int *) 0) = 0;
>>> (gdb) bt
>>> #0 0x40097f6b in invoke_abort () at /Users/casner/src/github/esp-idf/components/esp32/panic.c:140
>>> #1 0x400980c6 in abort () at /Users/casner/src/github/esp-idf/components/esp32/panic.c:149
>>> #2 0x401b8895 in duk_default_fatal_handler (udata=0x0, msg=0x3f4730b8 "uncaught error")
>>> at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:16634
>>> #3 0x402481e0 in duk_fatal_raw (ctx=0x3ffd4478, err_msg=0x3f4730b8 "uncaught error")
>>> #4 0x401ba5ca in duk__uncaught_minimal (thr=0x3ffd4478)
>>> at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:49604
>>> #5 duk_err_longjmp (thr=0x3ffd4478)
>>> #6 0x401c1aec in duk_throw_raw (ctx=0x3ffd4478)
>>> at /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/duktape/src/duktape.c:27697
>>> Backtrace stopped: previous frame identical to this frame (corrupt stack?)
>>> (gdb)
>>>> On Mon, 9 Jul 2018, Mark Webb-Johnson wrote:
>>>> I’ve enabled the javascript support in the ovms_scripts module. You can now write script files using the javascript language, and they will be run by the
>>>> duktape engine. Any script file ending with “.js” extension will be treated as javascript.
>>>> I’ve also added OvmsCommand and OvmsPrint extension commands.
>>>> Two examples:
>>>> Hello world!
>>>> OVMS# vfs cat /store/scripts/ota.js
>>>> OvmsPrint(OvmsCommand("ota status"));
>>>> OVMS# . ota.js
>>>> Running partition: factory
>>>> Boot partition: factory
>>>> Firmware: 3.1.008-40-g9254170-dirty/factory/edge (build idf v3.1-dev-1583-g0fb2019f Jul 9 2018 08:49:48)
>>>> Server Available: 3.1.008-37-g939416c (no update required)
>>>> Sat Jul 7 16:00:45 UTC 2018 Automated build (markhk8)
>>>> A useful example would be to have a script that runs on location.leave, and checks the v.e.gear metric for vehicle in Drive, before firing off the homelink
>>>> to close the garage door.
>>>> Like all good things, the opportunity for evil is forever prevalent (and truly scary):
>>>> OVMS# vfs cat /store/scripts/bruteforce.js
>>>> for (var pin = 1000; pin < 10000; pin++)
>>>> OvmsCommand("unlock " + pin);
>>>> OVMS# . bruteforce.js
>>>> V (1421374) canlog: TX can1 id 102 len 8: 0b 03 00 00 e8 03 00 40 | .......@
>>>> V (1421374) canlog: TX can1 id 102 len 8: 0b 03 00 00 e9 03 00 40 | .......@
>>>> V (1421374) canlog: TX can1 id 102 len 8: 0b 03 00 00 ea 03 00 40 | .......@
>>>> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 eb 03 00 40 | .......@
>>>> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 ec 03 00 40 | .......@
>>>> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 ed 03 00 40 | .......@
>>>> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 ee 03 00 40 | .......@
>>>> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 ef 03 00 40 | .......@
>>>> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 f0 03 00 40 | .......@
>>>> V (1421394) canlog: TX can1 id 102 len 8: 0b 03 00 00 f1 03 00 40 | .......@
>>>> I’ll leave it up to an exercise to the reader to change that script to use DukOvmsMetricValue() to monitor the v.e.locked metric to record success.
>>>> Note that this is very hacky and experimental at the moment. A better approach seems to be to have a javascript task running, initialised at boot with a
>>>> user’s javascript program. That can have timers, and whatever else it needs, to do it’s stuff. Then, scripts executed are run in the context of that task.
>>>> The current implementation is really just a proof of concept. The OvmsPrint is particularly kludgy (a better implementation would be to hook to the duktape
>>>> I/O system). Duktape is also currently running in internal RAM, although changing it to use SPI RAM should not be hard.
>>>> Regards, Mark.
>>>>> Begin forwarded message:
>>>>> From: GitHub
>>>>> Branch: refs/heads/master
>>>>> Home: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3
>>>>> Commit: f1736f927df582c5ff374ef5d8c3a565e8f67295
>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/f1736f927df582c5ff374ef5d8c3a565e8f67295
>>>>> Author: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>>>>> Date: 2018-07-09 (Mon, 09 Jul 2018)
>>>>> Changed paths:
>>>>> M vehicle/OVMS.V3/main/ovms_command.cpp
>>>>> Log Message:
>>>>> Javascript: Add a OvmsCommand function to execute an OVMS command
>>>>> Commit: 69427f4ac0cf68dc462b05752936befe4be22256
>>>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/69427f4ac0cf68dc462b05752936befe4be22256
>>>>> Changed paths:
>>>>> M vehicle/OVMS.V3/main/ovms_script.cpp
>>>>> Log Message:
>>>>> Javascript: Add a OvmsPrint function to be able to print a string
>>>>> JavaScript: Support .js script files (executed with javascript engine)
>>>>> Compare: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/compare/925417081d8e...69427f4ac0cf
>>>>> **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
>>>>> Functionality will be removed from GitHub.com <http://GitHub.com> on January 31st, 2019.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181222/83877b90/attachment-0001.html>
