[Ovmsdev] OvmsDev Digest, Vol 83, Issue 5
Olivier
ogrums at gmail.com
Sat Dec 8 17:08:47 HKT 2018
Hi Mark,
Before the update code is working to but with some error, I will fix my dbc
file to add signal for all message.
I have two question :
1. do you know how to config the dbc file to "compile" data from 2 Btye not
contigu ?
Example : ID 00FDF040 8 0x85 0x85 0x81 0x6A 0x7A 0xD9 0x4C 0x2E // ID
message contain 5 Cells Voltage
Cell 1 : #Byte 0 (0x85) | #LowByte 5 (0x9) => 0x859 => 2137 * 0,0015 =
3,2055Volts
Cell 2 : #Byte 1 (0x85) | #HighByte 5 (0xD) => 0x85D
Cell 3 : #Byte 2 (0x81) | #LowByte 6 (0xC) => 0x81C
Cell 4 : #Byte 3 (0x6A) | #HighByte 7 (0x4) => 0x6A4
Cell 5 : #Byte 4 (0x7A) | #LowByte 8 (0xE) => 0x7AE
the last Byte is the ID of BMS Board (0x2?)
2. The next step do after dbc load, How I can use information the value to
map or link with Standard metric ?
Thank you
Olivier
Le ven. 7 déc. 2018 à 05:00, <ovmsdev-request at lists.openvehicles.com> a
écrit :
> Send OvmsDev mailing list submissions to
> ovmsdev at lists.openvehicles.com
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> ovmsdev-owner at lists.openvehicles.com
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of OvmsDev digest..."
> Today's Topics:
> 1. Re: OvmsDev Digest, Vol 83, Issue 3 (Mark Webb-Johnson)
> Message: 1
> Date: Fri, 7 Dec 2018 09:19:41 +0800
> To: OVMS Developers <ovmsdev at lists.openvehicles.com>
> Subject: Re: [Ovmsdev] OvmsDev Digest, Vol 83, Issue 3
> Message-ID: <4F23B219-BDC5-4DA2-BAED-CC8380ABC720 at webb-johnson.net>
> Content-Type: text/plain; charset="utf-8"
> Olivier,
> Glad to see it is working again. I re-worked the dbc parsing code
> yesterday to allow sections to be in any order in the DBC (although the
> formal specification defines a specific order). That fixed your problem
> with loading the DBC?
> I tried your provided Vectrix_VX1.dbc with the day before yesterday?s
> 1bce372b20d4a79fb633faa6b96574604d95272f code, and get a segmentation fault
> on parsing it. With today?s master head, no problems and the file seems to
> load ok. The problem is the line 'BO_ 2164185677 FrontSensorRevision: 8
> FRONTSensor? - a message (BO_) without any signals (SG_). The newer code
> doesn?t care, but the older code couldn?t handle it.
> Regarding opendbc, yes I am aware of that. A very good resource. But, most
> (if not all) of those DBCs there have illegal structure. I think they are
> only used for human (not machine) reference. Things like section terms
> mis-spelled, missing semi-colons, values referring to signals or messages
> that don?t exist, etc. It is a good resource for testing broken DBC files
> > On 7 Dec 2018, at 4:37 AM, Olivier <ogrums at gmail.com> wrote:
> > Hello Mark,
> > It's strange, I have re-clone again to be sure about IDF,
> > $ git describe --tags --dirty
> > v3.1-dev-2835-g151269458
> > And now both is working, SD read and load dbc
> > I have add my dbc file, and if you want to test the is this git :
> https://github.com/commaai/opendbc <https://github.com/commaai/opendbc>
> > regards,
> > Olivier
> > Le jeu. 6 d?c. 2018 ? 05:16, <ovmsdev-request at lists.openvehicles.com
> <mailto:ovmsdev-request at lists.openvehicles.com>> a ?crit :
> > ovmsdev at lists.openvehicles.com <mailto:
> > http://lists.openvehicles.com/mailman/listinfo/ovmsdev <
> http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
> > ovmsdev-request at lists.openvehicles.com <mailto:
> > ovmsdev-owner at lists.openvehicles.com <mailto:
> ovmsdev-owner at lists.openvehicles.com>
> > Today's Topics:
> > 1. Re: Issue to store en SD Card after upgrade to idf 3.2-Dev
> > (Pull Request 2# from M4GNV5/master) (Mark Webb-Johnson)
> > Message: 1
> > Date: Thu, 6 Dec 2018 08:59:57 +0800
> > From: Mark Webb-Johnson <mark at webb-johnson.net <mailto:
> mark at webb-johnson.net>>
> > To: OVMS Developers <ovmsdev at lists.openvehicles.com <mailto:
> ovmsdev at lists.openvehicles.com>>
> > Subject: Re: [Ovmsdev] Issue to store en SD Card after upgrade to idf
> > 3.2-Dev (Pull Request 2# from M4GNV5/master)
> > Message-ID: <5B58BB15-BEB4-4B9E-AAFC-E98DFA176748 at webb-johnson.net
> <mailto:5B58BB15-BEB4-4B9E-AAFC-E98DFA176748 at webb-johnson.net>>
> > And related to this, if anyone else has any DBC files, please send them
> to me so that I can test them against our DBC support library (to test for
> robustness and completeness).
> > Regards, Mark
> > > On 6 Dec 2018, at 7:54 AM, Mark Webb-Johnson <mark at webb-johnson.net
> <mailto:mark at webb-johnson.net>> wrote:
> > > Olivier,
> > > I think this is two different issues.
> > > SD card issue
> > > Are there any system-level errors shown in the logs when you try this?
> Please try on local console to see what is shown there.
> > > Are you powered from USB or vehicle power?
> > > Can you show the output of ?config list sdcard? and ?sd status??
> > > DBC load issue
> > > Can you send me the Vectrix.dbc file you are using, please. Most
> likely something in the structure of this file is causing the crash. It
> seems that one of the messages (BO_) cannot be parsed correctly.
> > > What version of IDF are you using now? Just master head, right?
> > > Regards, Mark.
> > >> On 6 Dec 2018, at 4:29 AM, Olivier <ogrums at gmail.com <mailto:
> ogrums at gmail.com> <mailto:ogrums at gmail.com <mailto:ogrums at gmail.com>>>
> wrote:
> > >> Hello,
> > >> I have some issue with SD Card on OVMS 3.1 I don't know how to fix
> the "bug"
> > >> I can't write or read file on SD Card, but I can make directory :
> > >> OVMS# vfs ls /sd
> > >> [DIR] 05-Nov-2018 20:46 logs/
> > >> 13.5k 23-Nov-2018 19:45 Vectrix_bak.dbc
> > >> 14.0k 11-Nov-2018 22:04 Vectrix.dbc
> > >> 13 01-Jan-1980 00:00 FOO.TXT
> > >> 13.5k 23-Nov-2018 19:45 vx1.dbc
> > >> OVMS# vfs mkdir /sd/testdir
> > >> VFS directory created
> > >> OVMS# vfs ls /sd
> > >> [DIR] 05-Dec-2018 21:14 testdir/
> > >> OVMS# config backup /sd/cfg.zip
> > >> Creating config backup '/sd/cfg.zip'...
> > >> Error: zip failed: No such file or directory
> > >> OVMS# vfs rmdir /sd/testdir
> > >> VFS directory removed
> > >> And If I try do load dbc file it's crash
> > >> OVMS# dbc load test /sd/vx1.dbc
> > >> Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception
> was unhandled.
> > >> Core 1 register dump:
> > >> PC : 0x40271023 PS : 0x00060730 A0 : 0x800e38f1 A1
> : 0x3ffd4540
> > >> 0x40271023: dbcMessage::SetID(unsigned int) at
> ?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/dbc/src/dbc.cpp:935
> > >> A2 : 0x00000000 A3 : 0x80feda4d A4 : 0x3ffe5360 A5
> : 0x3ffe5363
> > >> A6 : 0x00000000 A7 : 0x00000000 A8 : 0x00000020 A9
> : 0x3f4055b0
> > >> A10 : 0x00000001 A11 : 0x3f4061ce A12 : 0x3f81ec50
> A13 : 0x00000000
> > >> A14 : 0x3ffd4524 A15 : 0x00000000 SAR : 0x00000008
> EXCCAUSE: 0x0000001d
> > >> EXCVADDR: 0x0000001c LBEG : 0x4009bd69 LEND : 0x4009bd9d
> LCOUNT : 0xffffffff
> > >> 0x4009bd69: memcpy at
> /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:291
> > >> 0x4009bd9d: memcpy at
> /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:324
> > >> Backtrace: 0x40271023:0x3ffd4540 0x400e38ee:0x3ffd4560
> 0x400dfeba:0x3ffd4ea0 0x400dea49:0x3ffd4ee0 0x400dec48:0x3ffd4f80
> 0x400f118a:0x3ffd4fa0 0x400f129b:0x3ffd4fd0 0x400f129b:0x3ffd5000 0x400f12
> > >> d1:0x3ffd5030 0x400ecae8:0x3ffd5050 0x4010601d:0x3ffd5070
> 0x4010608e:0x3ffd50d0 0x400ecb1f:0x3ffd5110 0x40271193:0x3ffd5130
> 0x401010a9:0x3ffd5150 0x400fa5cd:0x3ffd5180 0x400fa7e1:0x3ffd51b0 0x401
> > >> 00f35:0x3ffd51d0 0x40100f44:0x3ffd51f0 0x400f2489:0x3ffd5210
> > >> 0x400e38ee: yyparse(void*) at
> ?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/dbc/src/dbc_parser.y:306
> > >> 0x400dfeba: dbcfile::LoadFile(char const*, __sFILE*) at
> > >> 0x400dea49: dbc::LoadFile(char const*, char const*) at
> ?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/dbc/src/dbc_app.cpp:198
> > >> 0x400dec48: dbc_load(int, OvmsWriter*, OvmsCommand*, int, char const*
> const*) at
> ?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/dbc/src/dbc_app.cpp:62
> > >> 0x400f118a: OvmsCommand::Execute(int, OvmsWriter*, int, char const*
> const*) at
> ?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_command.cpp:73
> > >> 0x400f129b: OvmsCommand::Execute(int, OvmsWriter*, int, char const*
> const*) at
> const*) at
> > >> 0x400f12d1: OvmsCommandApp::Execute(int, OvmsWriter*, int, char
> const* const*) at
> > >> I Have try my SD Card on a PC is working, I have try example code
> "sd_card_example_main.c" from SDK "esp-idf\examples\storage\sd_card\main",
> It's working to, no crash.
> > >> My guest, is the hardware is OK, esp-idf is OK, but they is something
> in OVMS main code make this bug.
> > >> I have delete both esp-idf, and OVMS folder and clone again, compiled
> again, but it's the same issue.
> > >> Thank you for your help.
> > >> Olivier
> > >> _______________________________________________
> > >> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
> <mailto:OvmsDev at lists.openvehicles.com <mailto:
> OvmsDev at lists.openvehicles.com>>
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <
> http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181206/8ceb27f0/attachment-0001.html
> > Subject: Digest Footer
> > End of OvmsDev Digest, Vol 83, Issue 3
> > <Vectrix_VX1.dbc>_______________________________________________
> URL: <
> http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181207/34756cd8/attachment-0001.html
> End of OvmsDev Digest, Vol 83, Issue 5
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181208/3bc31106/attachment-0001.html>
