[Ovmsdev] Issue to store en SD Card after upgrade to idf 3.2-Dev (Pull Request 2# from M4GNV5/master)
Olivier
ogrums at gmail.com
Thu Dec 6 04:29:57 HKT 2018
Hello,
I have some issue with SD Card on OVMS 3.1 I don't know how to fix the "bug"
I can't write or read file on SD Card, but I can make directory :
*OVMS# vfs ls /sd*
*[DIR] 05-Nov-2018 20:46 logs/*
* 13.5k 23-Nov-2018 19:45 Vectrix_bak.dbc*
* 14.0k 11-Nov-2018 22:04 Vectrix.dbc*
* 13 01-Jan-1980 00:00 FOO.TXT*
* 13.5k 23-Nov-2018 19:45 vx1.dbc*
*OVMS# vfs mkdir /sd/testdir*
*VFS directory created*
*OVMS# vfs ls /sd*
*[DIR] 05-Dec-2018 21:14 testdir/*
*OVMS# config backup /sd/cfg.zip*
*Creating config backup '/sd/cfg.zip'...*
*Error: zip failed: No such file or directory*
*OVMS# vfs rmdir /sd/testdir*
*VFS directory removed*
And If I try do load dbc file it's crash
*OVMS# dbc load test /sd/vx1.dbc*
*Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was
unhandled.*
*Core 1 register dump:*
*PC : 0x40271023 PS : 0x00060730 A0 : 0x800e38f1 A1
: 0x3ffd4540*
*0x40271023: dbcMessage::SetID(unsigned int) at
?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/dbc/src/dbc.cpp:935*
*A2 : 0x00000000 A3 : 0x80feda4d A4 : 0x3ffe5360 A5
: 0x3ffe5363*
*A6 : 0x00000000 A7 : 0x00000000 A8 : 0x00000020 A9
: 0x3f4055b0*
*A10 : 0x00000001 A11 : 0x3f4061ce A12 : 0x3f81ec50 A13
: 0x00000000*
*A14 : 0x3ffd4524 A15 : 0x00000000 SAR : 0x00000008
EXCCAUSE: 0x0000001d*
*EXCVADDR: 0x0000001c LBEG : 0x4009bd69 LEND : 0x4009bd9d LCOUNT
: 0xffffffff*
*0x4009bd69: memcpy at
/home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:291*
*0x4009bd9d: memcpy at
/home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:324*
*Backtrace: 0x40271023:0x3ffd4540 0x400e38ee:0x3ffd4560
0x400dfeba:0x3ffd4ea0 0x400dea49:0x3ffd4ee0 0x400dec48:0x3ffd4f80
0x400f118a:0x3ffd4fa0 0x400f129b:0x3ffd4fd0 0x400f129b:0x3ffd5000 0x400f12*
*d1:0x3ffd5030 0x400ecae8:0x3ffd5050 0x4010601d:0x3ffd5070
0x4010608e:0x3ffd50d0 0x400ecb1f:0x3ffd5110 0x40271193:0x3ffd5130
0x401010a9:0x3ffd5150 0x400fa5cd:0x3ffd5180 0x400fa7e1:0x3ffd51b0 0x401*
*00f35:0x3ffd51d0 0x40100f44:0x3ffd51f0 0x400f2489:0x3ffd5210*
*0x400e38ee: yyparse(void*) at
?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/dbc/src/dbc_parser.y:306*
*0x400dfeba: dbcfile::LoadFile(char const*, __sFILE*) at
*0x400dea49: dbc::LoadFile(char const*, char const*) at
?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/dbc/src/dbc_app.cpp:198*
*0x400dec48: dbc_load(int, OvmsWriter*, OvmsCommand*, int, char const*
const*) at
?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/dbc/src/dbc_app.cpp:62*
*0x400f118a: OvmsCommand::Execute(int, OvmsWriter*, int, char const*
const*) at
?????/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_command.cpp:73*
*0x400f129b: OvmsCommand::Execute(int, OvmsWriter*, int, char const*
const*) at
const*) at
*0x400f12d1: OvmsCommandApp::Execute(int, OvmsWriter*, int, char const*
const*) at
I Have try my SD Card on a PC is working, I have try example code
"sd_card_example_main.c" from SDK "esp-idf\examples\storage\sd_card\main",
It's working to, no crash.
My guest, is the hardware is OK, esp-idf is OK, but they is something in
OVMS main code make this bug.
I have delete both esp-idf, and OVMS folder and clone again, compiled
again, but it's the same issue.
Thank you for your help.
Olivier
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20181205/6eefef38/attachment.html>
