[Ovmsdev] Lost configuration
Sat Aug 18 02:32:31 HKT 2018
On Fri, 17 Aug 2018, Tom Parker wrote:
> I have a backup (a bunch of commands in a txt file to paste into the console)
> so I did the full erase and set things up again. It has been operating
> normally for the 24 hours or so since.
You can also create a backup by copying the entire filesystem to
another computer using scp if you build the software with
CONFIG_OVMS_DEV_CONFIGVFS enabled.
