[Ovmsdev] How do I report a HW issue at Espressif?
Wed Aug 8 21:23:14 HKT 2018
I don’t think Espressif will help once the module has been put in a device/board. They’ve probably just direct you back to the supplier.
Anyway, let’s just confirm we don’t have another issue causing this (either corrupt firmware, or power issues):
Please power the device either from a powered USB hub, or from 12V. Best to also disconnect the modem board if you can. Then:
Please try to erase the chip, then re-flash from the standard firmware here:
$ make erase_flash
http://api.openvehicles.com/firmware/ota/v3.1/main/20180321.bootloader.bin <http://api.openvehicles.com/firmware/ota/v3.1/main/20180321.bootloader.bin>
http://api.openvehicles.com/firmware/ota/v3.1/main/20180321.partitions.bin <http://api.openvehicles.com/firmware/ota/v3.1/main/20180321.partitions.bin>
http://api.openvehicles.com/firmware/ota/v3.1/main/3.1.008.ovms3.bin <http://api.openvehicles.com/firmware/ota/v3.1/main/3.1.008.ovms3.bin>
… --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 <BOOTLOADER> 0x10000 <BIN> 0x8000 <PARTITIONS>
Reboot without a SD card in the slot and show me the output.
Also, please give the output of:
$ ~/esp/esp-idf/components/esptool_py/esptool/espefuse.py … summary
$ ~/esp/esp-idf/components/esptool_py/esptool/espefuse.py … dump
> On 8 Aug 2018, at 2:05 PM, Henrik Scheel <henrik.scheel at spjeldager.dk> wrote:
> My OVMS v3.1 module is failing to boot due to e-fuse CRC error.
> I am trying to open a support ticket at https://www.espressif.com/en/company/contact-extra/technical-inquiries-hardware <https://www.espressif.com/en/company/contact-extra/technical-inquiries-hardware>.
> First I had to confirm that I had done 76 advanced checks, ensuring that the hardware design is correct.
> Then I have to fill in a form, requesting information like:
> Name
> Work email
> Job Position
> Country
> Company
> Website
> Project Name
> Customer Product Part Number
> Design Version
> Espressif Product
> SDK Version
> And PCB layout
> So I guess I am using the wrong form.
> How do I contact Espressif regarding the e-fuse problem?
> Best regards,
> Henrik
> Venlig hilsen / best regards
> Henrik R. Scheel
> Spjeldager Consult ApS
> Spjeldager 9
> DK-2630 Taastrup
> CVR: 34491399
> T: +45 2720 9828
> http://www.spjeldager.dk/ <http://www.spjeldager.dk/>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180808/4d15b2d7/attachment.htm>
