[Ovmsdev] Porting code from v2 to v3
Wed Aug 1 04:32:56 HKT 2018
Nikolay,
that code does an OBDIIEXTENDED (16 bit PID) poll of the four PIDs 0x4965 … 0x4968 at module ID 0x753 (0b11101010011) with replies coming in at ID 0x75b.
That's something like this as a polling list:
static const OvmsVehicle::poll_pid_t obdii_polls[] =
    { 0x753, 0x75b, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0x4965, {  0, 1, 60 } },
    { 0x753, 0x75b, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0x4966, {  0, 1, 60 } },
    { 0x753, 0x75b, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0x4967, {  0, 1, 60 } },
    { 0x753, 0x75b, VEHICLE_POLL_TYPE_OBDIIEXTENDED, 0x4968, {  0, 1, 60 } },
    { 0, 0, 0x00, 0x00, { 0, 0, 0 } }
If you set this as a PidList and set the poll state to 1, the polls will be done in series with 1 second interval (every 60 seconds in state 2). Note that's 4
seconds for a full loop, not as fast as the old implementation which blocked the idle callback for 400 ms to send the requests with 100 ms delays.
If you really need these polls to be that fast (?), the polling framework needs some change, or you could continue to do this in custom code.
For a custom implementation you would define a software timer to be called every 100 ms. A single CAN TX may be possible to do within the timer callback (take
care: no blocking calls allowed). Another option would be to generate a custom poll request or 100 ms ticker event from the timer callback and use an event
handler to actually do the TX.
Am 31.07.2018 um 20:57 schrieb Nikolay Shishkov:
> Quick question.
> How do I convert this:
>     while (TXB0CONbits.TXREQ) {} // Loop until TX is done
>     TXB0CON = 0;
>     TXB0SIDL = 0b01100000;
>     TXB0SIDH = 0b11101010;
>     TXB0D0 = 0x03;
>     TXB0D1 = 0x22;
>     TXB0D2 = 0x49;
>     TXB0D3 = 0x65;
>     TXB0DLC = 0b00000100; // data length (4)
>     TXB0CON = 0b00001000; // mark for transmission
>     delay100b(); // Delay a little... (100ms, approx)
>     TXB0CON = 0;
>     TXB0D0 = 0x03;
>     TXB0D1 = 0x22;
>     TXB0D2 = 0x49;
>     TXB0D3 = 0x66;
>     TXB0CON = 0;
>     TXB0D0 = 0x03;
>     TXB0D1 = 0x22;
>     TXB0D2 = 0x49;
>     TXB0D3 = 0x67;
>     TXB0CON = 0;
>     TXB0D0 = 0x03;
>     TXB0D1 = 0x22;
>     TXB0D2 = 0x49;
>     TXB0D3 = 0x68;
> To the new polling framework?
> I took a look at the leaf code, but the configuration is a mystery to me. What are the input parameters?
> Maybe there is a document that I am missing?
> Thanks in advance,
> Nikolay
> On Saturday, July 28, 2018, 11:42:13 PM GMT+2, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
> Thank you!
> Yes the carid is TC003.
> I was not running anything extraordinary - just followed the developer tutorial, but never flashed directly - always flashed from edge branch OTA.
> I will run the commands and provide output, but it will be with the newer firmware.
> I will need to see if updating will have same problems.
> On Friday, July 27, 2018, 3:07:09 AM GMT+2, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Note that I store the .elf files alongside the .bin, for edge/eap/main builds.
> For example:
>     http://api.openvehicles.com/firmware/ota/v3.1/edge/3.1.008-29-gaf41242.ovms3.elf
>> On 27 Jul 2018, at 5:51 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
> Nikolay,
> you need to keep the .elf files for your builds to be able to analyze a backtrace. Do not use addr2line, it shows wrong line numbers. Use the script "a2l" I
> posted previously (I'll include it again below). Just feed it the .elf file and the backtrace. Example:
> a2l tmp/3.1.008-32-g2fa3ab8-elf/ovms3.elf 0x400dc8ec 0x4008f43d 0x4008e181 0x400818cc 0x40082163 0x40083c4d 0x400dc8e9
> (I don't have the -28- version, so my output doesn't make sense)
> @Mark: spurious task WDT crashes and heap corruption crashes still occur, but it seems they have become less often with the internal RAM rework.
>> How is performance and power usage affected when using StandardMetrics.xxxxx->SetValue in the IncomingFrameCan1 method?
>> Most of the messages update value every 100ms, and except maybe speed, battery current and voltage, most of the parameters are not changing that often. And
>> even for the speed, current and voltage, it is probably enough to update StandardMetrics in the 1 second ticker... does this make sense or is the difference
>> non-existing.
> Extending Mark's answer:
> It's normally OK to directly set metrics from IncomingFrameCan1(), but be aware metrics listeners will be executed synchronously in the context that changes
> the metric.
> Standard metrics listeners are now for example the automatic notification generators in the vehicle base class. These may need quite some stack and time.
> If you spend too much time handling frames on a high volume bus, your vehicle task may lose frames. It's possible to raise the queue size (currently 20
> frames) and the vehicle task stack size, but it's better to keep the CAN processing simple.
> TL;DR: if you need to handle many CAN frames, I recommend changing metrics that trigger notifications or other complex actions from the ticker. If you
> encounter crashes on some CAN frames that may be due to the vehicle task stack being too small (CONFIG_OVMS_VEHICLE_RXTASK_STACK=6144).
> Script a2l:
> #!/bin/bash
> elf=~/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf
> for adr in $* ; do
>   if [[ "$adr" =~ "elf" ]] ; then
>     elf="$adr"
>   else
>     cmd+=" -ex 'l *$adr'"
>   fi
> done
> cmd+=" -ex 'q'"
> echo "Using elf file: $elf"
> eval xtensa-esp32-elf-gdb -batch $elf $cmd 2>/dev/null #| grep "^0x.* is in "
> Am 26.07.2018 um 09:59 schrieb Nikolay Shishkov:
> Quick update:
> I managed to do a not so quick update on one of the ovms v.3 boxes that sits in a Think and can confirm that the porting seems to work.
> I could see speed, parking time, ambient temperature.
> I had very strange problems doing the OTA update. The firmware start download and I can see the messages progressing, but it would halt in between 700kB and
> 1600kB and then stay there until I refresh the browser.
> And when I refresh the browser I am asked of my password which leads me to that there must have been a crash in the meantime.
> I was finally able to get the OTA update work by disconnecting the box from the car and powering it via USB. This is a single data point but it kind of points
> to a problem with the code that communicates with the car.
> I was not able to get a laptop connected to checkout the console, but managed to get the following log - not sure how to interpret it.
> Last boot was 87 second(s) ago
> Time at boot: 2018-07-25 18:07:43 GMT
> This is reset #3 since last power cycle
> Detected boot reason: Crash (12/12)
> Crash counters: 3 total, 0 early
> Last crash: Alloca exception on core 0
> Registers:
> PC : 0x400dc8ec PS : 0x00060234 A0 : 0x8008f440 A1 : 0x3ffc45b0
> A2 : 0x00000020 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x3ffb44b8
> A6 : 0x3ffb47e4 A7 : 0x3ffb458c A8 : 0x3ffb44d4 A9 : 0x3ffc4590
> A10 : 0x00000000 A11 : 0x7fffffff A12 : 0x8008e65b A13 : 0x3ffcc450
> A14 : 0x00000003 A15 : 0x00060023 SAR : 0x00000000 EXCCAUSE: 0x00000005
> EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
> Backtrace:
> Version: 3.1.008-29-gaf41242/ota_1/edge (build idf v3.1-dev-987-g55d915e Jul 6 2018 00:14:59)
> Running partition: ota_1
> Boot partition: ota_1
> Firmware: 3.1.008-29-gaf41242/ota_1/edge (build idf v3.1-dev-987-g55d915e Jul 6 2018 00:14:59)
> non-existing.
> Thanks for all the hand holding and help,
> Nikolay
> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180731/c3687b91/attachment.htm>
