[Ovmsdev] Config store mount failure / reformatting
Thu Aug 23 15:16:20 HKT 2018
Doing…
git pull
git reset --hard 812f959cec635cb7a849085bcc46711bd57ff0c9
git submodule update
…should be correct, but creating a fresh clone is of course also an option.
These directories:
> warning: unable to rmdir 'components/asio/asio': Directory not empty
> warning: unable to rmdir 'components/expat/expat': Directory not empty
…can be removed.
Am 23.08.2018 um 07:45 schrieb Craig Leres:
> On 8/22/18 8:49 AM, Michael Balzer wrote:
>> OK, our esp-idf repository is now rolled back to the previous commit.
>> After pulling you may need to explicitly "git checkout master" -- verify you're on commit 812f959cec635cb7a849085bcc46711bd57ff0c9.
>> You also will need to do a "git submodule update" afterwards.
> Hum... My "update.sh" script says:
> #!/bin/sh
> set -x
> git pull
> when I run it I'm, "Already up to date."
> If I do "git checkout master" it says:
> Already on 'master'
> Your branch is ahead of 'origin/master' by 378 commits.
> (use "git push" to publish your local commits)
> google tells me the way to show my current git hash is:
> ice 472 % git rev-parse HEAD
> 88e6723d487fe91bae5c09f7534d5b78e327dbad
> which doesn't match. google gave me a way to go to a specific hash:
> ice 473 % git reset --hard 812f959cec635cb7a849085bcc46711bd57ff0c9
> HEAD is now at 812f959c Merge pull request #1 from leres/master
> ice 474 % rm -rf components/asio/asio components/expat/expat
> ice 475 % git reset --hard 812f959cec635cb7a849085bcc46711bd57ff0c9
> I'm embarrassed to admit I'm so lame at git but I haven't been able to wrap my head around it so far. It all seems like arbitry magic as far
> as I can tell. I started with sccs, did a lot with rcs and went "all in" with subversion 10-15 years ago.
> I tried to flash my module but it looks like it already lost its config so I take it "module factory reset" is the best starting point?
> Craig
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180823/420e5e68/attachment.html>
