[Ovmsdev] Config store mount failure / reformatting
Craig Leres leres at xse.com
Thu Aug 23 13:45:12 HKT 2018
On 8/22/18 8:49 AM, Michael Balzer wrote:
> OK, our esp-idf repository is now rolled back to the previous commit.
> After pulling you may need to explicitly "git checkout master" -- verify
> you're on commit 812f959cec635cb7a849085bcc46711bd57ff0c9.
> You also will need to do a "git submodule update" afterwards.
Hum... My "update.sh" script says:
     #!/bin/sh
     set -x
     git pull
when I run it I'm, "Already up to date."
If I do "git checkout master" it says:
     Already on 'master'
     Your branch is ahead of 'origin/master' by 378 commits.
       (use "git push" to publish your local commits)
google tells me the way to show my current git hash is:
     ice 472 % git rev-parse HEAD
     88e6723d487fe91bae5c09f7534d5b78e327dbad
which doesn't match. google gave me a way to go to a specific hash:
     ice 473 % git reset --hard 812f959cec635cb7a849085bcc46711bd57ff0c9
     warning: unable to rmdir 'components/asio/asio': Directory not empty
     warning: unable to rmdir 'components/expat/expat': Directory not empty
     HEAD is now at 812f959c Merge pull request #1 from leres/master
     ice 474 % rm -rf components/asio/asio components/expat/expat
     ice 475 % git reset --hard 812f959cec635cb7a849085bcc46711bd57ff0c9
I'm embarrassed to admit I'm so lame at git but I haven't been able to
wrap my head around it so far. It all seems like arbitry magic as far as
I can tell. I started with sccs, did a lot with rcs and went "all in"
with subversion 10-15 years ago.
I tried to flash my module but it looks like it already lost its config
so I take it "module factory reset" is the best starting point?
		Craig
