[Ovmsdev] Fwd: OVMS Nightly Firmware Build 3.1.009
Wed Aug 15 20:27:45 HKT 2018
Enjoy
> Begin forwarded message:
> From: mark at openvehicles.com
> Subject: OVMS Nightly Firmware Build 3.1.009
> Date: 15 August 2018 at 8:11:30 PM HKT
> To: mark at openvehicles.com
> 3.1.009
> Wed Aug 15 12:11:30 UTC 2018 Automated build (markhk8)
> Total sizes:
> DRAM .data size:   16452 bytes
> DRAM .bss  size:   32864 bytes
> Used static DRAM:   49316 bytes ( 131420 available, 27.3% used)
> Used static IRAM:  107932 bytes (  23140 available, 82.3% used)
>      Flash code: 1328694 bytes
>    Flash rodata:  612052 bytes
> Total image size:~2065130 bytes (.bin may be padded larger)
> * 92d8501 (HEAD, tag: 3.1.009, origin/master, origin/HEAD, master) Known Issues, ready for 3.1.009
> * 9dd6131 Changes and TODO, ready for 3.1.009
> *   8724c1d Merge pull request #152 from caederus-ovms/units
> | * e0aa195 Use correct SI unit abbreviations for distance (km), speed (km/h), acceleration (km/h/s - as an alternative to the usual m/s²).
> | * 51ce2a2 If converting value to different unit, AsUnitString() should also convert unit name.
> * 3c05772 TeslaModelS: Add support for CAN2 and CAN3, and decode MCU GPS lat, lon, heading, and HDOP
> * 0e3c6d4 Twizy: fix missing charge records in RT-PWR-Log
> * 7192be1 Minor command description changes to sync with user guide
> * 3704933 Wifi: add RSSI level to status output
> *   4cf3dba Merge pull request #150 from bobbo3/master
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180815/bd6a2a63/attachment.html>
