[Ovmsdev] openssh 6.7 cipher aes128-cbc
    Fri Apr 27 13:27:04 HKT 2018
>> It would be good to have a menu config option to define DEBUG_WOLFSSH.
> I think the only penalty for enabling it always is an increase in code
> size, ssuming the "_impure_ptr" is fixed in some way.  I asked Mark if
> that would be reasonable to enable always.
I guess it depends on how much bigger. Debugging the internals of wolfssh is seemingly a rare occurence? Perhaps a menuconfig option (in Components / OVMS / Developer Options) would make sense?
> On 27 Apr 2018, at 1:16 PM, Stephen Casner <casner at acm.org> wrote:
> On Thu, 26 Apr 2018, Robin O'Leary wrote:
>> On Fri, Apr 20, 2018 at 11:39:18PM -0700, Stephen Casner wrote:
>>> On Fri, 20 Apr 2018, Robin O'Leary wrote:
>>>> OK, so that started me on quite an adventure in to compiler errors
>>>> and git submodules,
>>> Sorry, did my commit of an update to mongoose trip you up?
>> That was just one of several things, but one of the easily resolved ones!
>> Much more annoying was a mysterious error about an undefined reference to
>> "_impure_ptr", since that appears nowhere in the code.  I tracked it
>> down to the fprintf in wolfssh/src/log.c; I still don't understand why,
>> but I just commented it out, as ovms uses logFunction instead.
> Oh, I do remember hitting that one myself and having to use Google for
> help.  I think I hit that when I tried to add a printf statement of my
> own, so maybe if I saw it when enabling DEBUG_WOLFSSH I used the same
> workaround that you did.  I had not remembered that problem when
> suggesting that you try DEBUG_WOLFSSH.  Sorry.
>>> Perhaps I
>>> should configure in the debug code for wolfssh and wolfssl by default
>>> so the extra logging can be enabled whenever it is needed.
>> Adding more calls to GetErrorString() in ssh.c is probably more helpful.
> That is done, but there is only one error code that is returned for
> any cipher, MAC or key mismatch, so DEBUG_WOLFSSH is still required to
> figure out which one.
>>> WolfSSH also supports aes128-ctr and aes128-gcm, but I was warned that
>>> the latter is much more expensive in speed and memory, so I excluded
>>> it from the configuration for compilation.
>> I think there is full support for aes128-ctr in wolfssl/wolfcrypt, but
>> the places where it needs to be in wolfssh seem to be mostly missing.
>> I had a go at adding it, but I haven't got it working.  It does connect,
>> but auth always fails.  I haven't had chance to figure out why yet.
> wolfssh/src/internal.c does reference AES128_CTR in a few places, but
> I'm not sure what actions are required.
> I started with WolfSSH 1.1.0 when doing the integration into OVMS.
> There is a 1.2.0 release out now (on github at wolfSSL/wolfssh), and a
> 1.3.0 release pending that will include Wolf's integration of my SCP
> additions back into their code base.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180427/0e044350/attachment.htm>
